Results 1 to 10 of 31
June 19th, 2005 12:45 PM #1
today i noticed thin white smoke coming out of my tail pipe... so i checked the breather hose, there is also thin white smoke coming out... IS MY PAJERO BLOW-BY???? btw, its a 4D56 TDIC A/T Pajero..
TIA
June 19th, 2005 02:59 PM #2
Blue White Tinted Exhaust Smoke
A perfectly healthy diesel will have no visible exhaust smoke except for start up and acceleration. A little blue smoke (oil burning) on start up is normal and some diesels will have a bluish smoke at idle that should disappear with increased throttle. I don’t like to see any blue smoke but not all diesels are perfect. I remember one of my automotive teachers comments about a light blue smoke from an old truck engine, he said, “That’s just good lubrication”. (Today that truck wouldn’t pass emissions testing, sorry teach). Blue smoke that stays in the exhaust throughout the RPM range is another reason to do more investigating. If I see a lot of blue smoke, red flag! I always keep in mind that blue smoke in the exhaust is a sign of lubricating oil burning in the combustion process, not a definite reason to say that the engine is worn out. Oil can be slipping past the engine rings because it is diluted with diesel fuel. There can be a bad turbo charger seal, a clogged air filter (a very bad sign about maintenance), or there can be oil in the fuel!
Accurate Machinery LLC
other info i got was about PVC's.. clogged up PVC would also seem like a blow by engine.. where is the PVC in the 4d56 engine located?? is it the breather hose on top of the valve cover??
tia
- Jun 2004
- 476
June 19th, 2005 07:12 PM #4I agree. Have a compression test done immediately. Compression figures from a 4d56 workshop manual:
Standard figures - 3,040 kPa * engine speed of 280 r/min
Minimum limit - 2,200 kPa * engine speed of 280 r/min
Difference between cylinder readings should not exceed 300 kPa
Has your rig been burning oil lately? On a diesel engine white smoke usually means diesel fuel could be mixed in your oil. Check the bypass plug of the fuel injector. If there's a leak here diesel fuel goes directly in your engine.
Didn't you have your turbo cleaned/serviced recently? As stated in your post lifted from Accurate Machinery, it could also be a busted turbo charger seal.
Hope this helps.
June 19th, 2005 09:39 PM #5
tnx for the tip.. know any shop that does compression testing near manila area?? als how much does it cost?
yes paj, i had my turbo cleaned recently.. and had that seal replaced, will also try to check out if the turbo is oily again..
i have logged 3T kms since my last change oil ad there were'nt any sign of loss of oil... however, last month i went up to baguio and before going down i checked again the oil dipstick, it read lower.. so i added almost half a liter of oil... since then. i've been checking if my rig still consumes, and it does'nt....
June 19th, 2005 10:13 PM #6
What about the diesel-CRDI engines? Is it normal having the same color of smoke?
June 20th, 2005 10:01 AM #7
AutoTechnica along Commonwealth Ave (right after fairview market if you are coming from EDSA) offer compression testing. They charge 300 (or 150 yata) per cylinder for 2.5 - 3.0 liter engine. Here's the contact number: 4616400 - 04, Ernie Reyes Service Manager (9202204845). You have to be early as you need to cool down the engine to conduct compression testing.
June 20th, 2005 10:56 AM #8
if your rig consumes oil excessively without leaks.... well... im sorry to break the bad news but yeah, most likely.
But hey, i could be wrong.... compression test na!
June 20th, 2005 12:46 PM #9
i checked out the turbo, its not oily... also there's nomore white smoke coming out of my tailpipe today... hmmm its driving me nuts! :lol:
checked again the dipstick.... no signs of oil depletion..
thanks for the info on the compression test. will visit them one of these days..
btw.. my breather hose, on the valve cover is disconnected from the intake since oil coming out of it is another reason for clogging up the turbo... i just leave it pointing down, and its now oily in that area... is it normal that hose to get so oily? ai'nt it another sign of blowby?
tiaLast edited by v22; June 20th, 2005 at 12:50 PM.
June 20th, 2005 05:02 PM #10
Originally Posted by v22
O/T question lang po...
Is it normal for exmaple like engine of mine D4D to have oil coming out of the breather hose of the valve cover also??
I found this out that there's oil on the rubber tube(where breather hose of valave cover connected) that's sucks air from air filter...
WBR,
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
