Results 11 to 20 of 31
June 20th, 2005 05:04 PM #11
That happens when you rev too hard on a diesel. Yes it can be considered normal.
- Jun 2004
- 476
June 20th, 2005 09:18 PM #12I'd also recommend Autotechnica. Log on to www.4x4ph.com and PM johnqpublic318. He can help you out.
Originally Posted by v22
June 20th, 2005 09:54 PM #13
check if there's oil coming out of your dipstick. of course, check this while the engine is running.
June 27th, 2005 08:46 PM #14
afrasay;
i checked it yesterday while the engine is running and was already warmed up.. yes, oil seems to splash/talsik upwards.. is this a sign of blowby???
June 29th, 2005 02:26 PM #15
teng,
base sa description mo, mukhang blow-by na nga yan. just to be sure, pa-compression test para walang guessing-guesing.
and if indeed it's blow-by, change engine ka na lang! 4m40 para sulit.
- Jun 2005
- 17
July 3rd, 2005 02:48 AM #16Hey I would also like to know I just had my injection pump calibrated when I got the car there was black smoke when I accelerate . I changed the air filters and they checked the oil stick when the engine was running white smoke was coming out but no oil splurting. The technician said that the engine was blowby is this true. But there was no oil loss before they calibrated it. Or I just have to have an oil change and put additive baka mawala.
July 3rd, 2005 12:38 PM #17Originally Posted by bogart
btw, i went up to baguio again and there were no signs of oil consumption, and no white smoke when the engine is hot.... but oil still splatters when i take off the dipstick while the engine is running...
also engine is resonsive, no problems negtiating uhill climbs and cruising 140kph at nlex..
haay nakakalito!
July 3rd, 2005 12:45 PM #18
deym...nakakalito naman ang facts!!ahrharharhahr
hirap mag diagnose!parang niloloko tayo ng engine...herhehrer..well...those are signs.sa ngayon, cant conclude parin.wag na gumamit ng mga additives na yan..makakasama lang yan or at least, sayang lang epra niyo.
- Aug 2006
- 13
August 17th, 2006 04:25 PM #20Hi to everyone,
I've just registered this afternoon, and found this thread interesting.
I’m experiencing the same with my ’99 Starex 4D56 TD. The engine is running smoothly, no oil burning, no foul or heavy smoke and easy to start. However, I replaced the piston rings by size 0.25. The oil spilling out of the dipstick stops but after 4mos oils started to spill again. But still the engine is running smoothly same as before I made “dukot”. Any idea why pressure is building up in the crankcase other than loose rings.
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
