Ay yan ang wala ako idea he he. Bakaniba dyan may alam. Wait natin comment nila.
Fasten your seatbelt! Or else...Driven To Thrill!
Bago lang po ako sa forum and i just recently bought a 99 pajero fieldmaster. Di ko alam na kailangan pala i-cool down ung turbo before shutting down the motor. Nagtravel ako from antipolo to tagaytay just recently and did not do the cool down after the trip. May masisira ba agadsa turbo ko? Do i need to have it checked? Paano ko ba malalaman kapag may turbo timer ako? Salamat!!!
hindi naman agad basura yan... like your shoes it takes awhile before pwede itapon.
you already mentioned the turbo timer...it is a timer. its like waiting a minute or two before switching off the engine
Galing ako kanina sa Motorix pra pa-check kung saan nanggagaling yung ugong tuwing tinatapakan ko yung gas pedal. Pinalitan nila yung gear oil ng GL4 SAE140. Mukhang nawala naman na yung ugong... Tanong ko lang kung tama ba yung nilagay nilang gear oil kasi nabasa ko sa thread dati dapat daw GL5 SAE90 pra gear oil. FM '03 po unit ko. Thanks.
Good day, hingi lang ng advice. I noticed lately na may leak sa transmission near the oil pan. Kailangan daw ibaba. Would appreciate recommendation kung sinong trusted FM mechanic in QC or anywhere in Metro Manila.
Thank you very much for the assistance.
saan kaya pwede magpagawa ng seatcover na tela lang para sa pwet lang? pwede kaya yun? or kailangan talaga isang set?
pag mataas kasi sasakyan.. mabilis maluma upuan dahil sa rubbing paakyat pababa
Mga paps san kaya may available knn air filter drop in for space gear 2003 ilalagay, 4d56T
Sent from my SM-G935W8 using Tapatalk
Bought 4 yokohama geolander a/t 265/70 R16 for 6,800 a piece. Free na mounting, balance, tingga, nitro. Nka mura na po ba ako? Salamat.
Sent from my SM-G935W8 using Tapatalk[/QUOTE]
what's a fair value for an '06 FM? and what are the things i should watch out for? really tempted to get one.
Try mo sa Motorix. Kung same case yan nung sa akin, yun oil seal sa may crankshaft yun bumigay. Kelangan talaga ibaba transmission niyan. Mura lang naman piyesa niyan pero mahal ang labor at iiwan mo yun sasakyan.
Parang meron ako nakita mga around 600k for '06 model. Check mo lang yun mga ito sa unit
1. shifting
2. brakes
3. paint condition
4. interior condition
5. engine bay for oil leaks
Sirs, ano po ma-recommend nyo na bulbs para sa headlight and foglights? Para mas malakas lang ang buga? TIA.
mga gurus need help po... Yung aircon ng FM ko nagloloko... Last month galing ako TA Fresco pra magpa cleaning ng aircon pinalitan lahat o-rings, exp valve flush system, charge freon. Wala pa 1 week binalik ko at uminit ulit.. Ang sabi sa akin naluto daw yung freon kya charge nila ulit freon. Ilang araw lang uminit ulit kya balik nanaman. Sabi ng 1 gumagawa duon naka encounter na daw sya ng pajero na ganun pinalitan nya daw condenser umayos na yung lamig. Sabi ko gumagawa palitan nalang natin condenser pra baka umayos na. Palit kami condenser tapos charge freon. Obserbahan ko daw kung magloko pa. Kinabukasan wala nanaman lamig kya balik nanaman ako banawe. Ang ginawa ngayon palit freon tapos ng makita na di lumalamig tinanggal freon tapos pinakuha yung unang pinarating na freon kasi daw mas maganda yun. Lumamig nga nung yun na nilagay. Ang sabi sa akin maselan daw kasi talaga mga FM kaya ganun. Meron din daw sila dati customer pabalik-balik sa kanila kasi nag hihigh pressure madalas yung unit.. Tumagal lang 3 days yung lamig ng FM ngayon wala nanaman.. Napapansin ko rin lang parang ang sobrang init sa loob ng engine compartment. May naka pag sabi pala sa akin na yung FM nya dati ganun din pinalitan nya ng radiator tumino na daw yung lamig. Ano na po kya gagawin ko? Bat lagi nalng naghihigh pressure yung FM ko? Di kaya maganda yung freon o kelangan ko nga palitan yung radiator?
