Mawawala din tubig ko when I got my FM. I changed the radiator to a new one. Puede diy lang. New Radiator cost almost 6500. Nawawala parin yung coolant, wala naman leak under the engine. Then I check my engine oil, no signs of water in the oil. After using it for more than a month. I discovered that one of the big hose from radiator to engine is stretch. No leaks when I started the engine. When engine warmed up to temp, a few drops will squish out and hit the engine. But it eventually dried up due to the hot engine. The leak normally happen sa engine side of the radiator hose. The hot engine will loosen up the hose after a few years. I just bought a bnew upper radiator hose. It's ok now for 2 years. No need to add water
o sir, taga cebu ko. ngita unta ko 2nd opinion sir kung cyl head ba gyud blema ani kay na reface ug crack test naman ni sa machine shop, unya murag mao man gihapon sir.
in case kung angay gyud ilisan iya cyl head, kung ok raba nang replacement from taiwan. salamat sir
Browse ka sa Ebay ang daming cylider head ng 4m40 na brand new to give you an idea.
sir Dencio and sir nelany, maraming salamat po sa advice nyo sir.
more than 2 years na gamit...worth siguro 'to e consider sir.
thank you po sa inyo mga sir
Bro, i know the owner of automekanika si john enad. He has a shop somewhere in Mabolo man siguro.
Good pm, patulong lang sana anu maadvice nyo na size ng goma for size 17 na mags??? Pasama na din sir offset ng mags planning to buy sana. Thanks
