cb , eto yung boost gauge sa FM ko. Hindi ba set yung boost gauge na nabili mo? Sa akin kasama lahat na so wala na akong binili na iba. Can also check yung max boost at a given time by pressing yung PEAK button sa gauge.
Yung sa ito ba mechanical o electronic gauge? Pag electronic palagay mo yung sensor sa loob dash, huwag sa engine bay.
Hindi ata yung may crimp and kelangan palitan. From the pic yung nasa middle ang may crack as mentioned by K.I.L.L. I suggest dalhin mo na lang sa mga auto shop, meron yan sialng hose dyan. Nagpalit na ako yung maiksi niyan, return hose ata ng PS din. Parang P120 lang iirc.
Yan mahaba kunti kaya baka mga P250 or up.
Maraming salamat mga kasama. Either doon sa Central Diesel o sa Malabon Diesel ako pupunta para magpa-calibrate. Pero oobserbahan ko muna yun sasakyan bago ko talaga pa-calibrate. May kamahalan din pala magpa-calibrate
Thanks CB,CoDer and Ry_tower. Would Joseph Atutubo have stock of the hose if I bring it to him?
No problem sir. Unfortunately I can't give you any info that may help you as I'm from Pangasinan.
And I simply leave my car to my trusted mechanic pag may problema at sya na ang bahala including the sourcing out of parts. Wag lang sensors ang mag luko dahil ang linya kaagad sa akin nun eh.. "Boss sa casa na lang muna yan."![]()
Nahirapan na naman umistart yun sasakyan after work. We're gonna take a look sa glow plugs kung may busted. Pero I really doubt that dahil bagong palit lang yan about 3 weeks ago nung nagpachange oil ako.
Nope, fuel is not dark nung nagpalit ako ng fuel filter. As far as yun usok is concerned, meron na konti. We're considering na ipa-calibrate na rin talaga yun sasakyan pero not now since ok pa naman yun condition.
Kakatapos lang namin i-check ng tatay ko yun sasakyan. We checked the glow plugs. Di namin inaasahan na... 2 weeks after kong ipa-preventive yun sasakyan, pundido na ang lahat ng bagong glow plugs ko. Tested each glow plug's continuity using multimeter pero walang palo. Buti at meron pa kaming old stock ng glow plugs galing sa JDM namin. Checked it's continuity at meron naman. So nagpalit kami ng glow plugs in an instant.
Ngayon, nag-iisip tuloy kami kung bakit ang bilis mapundi nung bagong glow plugs. Napaisip kami na baka peke yun mga yun. Sa Speedlab pa naman ako nagpa-change oil bago mag Undas.
Baka nga peke yung glowplug. Yung sa akin ay taon na at oks pa rin hkt rin ang brand
Dami talagang fake na HKT. Sa strada nangyari na nga sa akin almost a week lang iirc eh busted na din.
Try mo yung CP-05, yun naman dapat sa pajero na 4m40 eh. Overall length ng PM-165 is 88mm and 89mm for CP-05. More importantly, the length of the element for the PM-165 is 1mm longer for the CP-05. I don't know if that is a factor for clearance inside the cylinder but it might be a reason since it may mean mas naabot siya ng combustion. Also the CP-05 is 0.7mm fatter at the element. Maybe a thicker element might make it more durable.
http://hiflo.com.au/pdf/HKT%20GLOW%20PLUG%20X-REF.pdf
Naalala ko si nelany yata nag post nung picture dati nung glow plugs na para sa 4M40 talaga
