Page 1026 of 1435 FirstFirst ... 9269761016102210231024102510261027102810291030103610761126 ... LastLast
Results 10,251 to 10,260 of 14348
    Dec 2013
    #10251
    Quote Originally Posted by tata_ismael View Post
    Didn't weigh mine.. Pero ironman estimated around 30-40kgs ang front bumper.. Medyo dumapa nga ulo ng FM ko when I installed the bumper.. Kaya I ordered ironman shocks na sabay adjust ng torsion bars nextweek.. FC was not affected sir.. Para ka lang nagsakay ng isang chicks.. Hehehe
    Problema sira FM ko.. Nagpa change oil ako kahapon sabay oil filter & air filter.. Drove it home tapos biglang medyo palyado after 5minutes of driving.. Inisip ko baka kulan lang ng bleeding yung fuel filter.. Ginamit ko kagabi, medyo palyado pa rin to the point na namatayan ako while slowing down.. Pero nakauwi naman ng house.. Tapos kanina palyado na talaga.. Kahit anong bleeding ko ng fuel filter palyado pa rin.. Pinainit ko to normal operating temp pero palyado pa rin.. Mekaniko na bahala nito bukas..
    Sana minor like like a bad fuel filter or a leak somewhere.. Huwag lang sana injection pump.. It was running fine before the PMS..
    Hahay
    Baka sir hinde marunong nag palit ng fuel filter mo. Dapat kasi bobombahin mo yan yung pinaka filter para malamnan ng crudo or else yan ang effect papalya at mamatayan talaga...
    Apr 2008
    #10252
    Sir KILL, tinanggal kasi nahihilaw na yung lamig sa likod. Check vavlve lang naman daw ton just in case ayaw mo buksan yung aircon sa likod.
    Posted via Tsikot Mobile App
    Feb 2014
    #10253
    Mga sir. San po ba pwede ipaayos yung kalampag sa upuan or anong pwedeng gawin? 3rd row ko ata yung maingay
    Dec 2013
    #10254
    Quote Originally Posted by specialtikoy View Post
    Sir bench type ba ang third row mo? yung sakin kasi dati maingay yun pala maluwag lang yung knot ng nagdudugtong sa sadalan at yung pinaka tinutupi na bench. Hinigpitan ko lang ok na.
    Dec 2013
    #10255
    Mga sir ano mas ok kumuha ng montero sport first hand or pajero bk na second hand?
    Apr 2008
    #10256
    Mga sir baka meron ng naka experience nito, nagsimula problem ko sa aircon ng mahilaw yung lamig sa likod, nag pa cleaning ako tapos sabi tanggalin na lang daw ung solenoid valve sa likod. Di rin naman na solve ang problema, so nagpunta nko ibang shop, sabi sa akin mahina na daw bumomba compressor ko. Ka batch ko ng college ung may ari ng shop so sinamahan nya lang ako sa supplier nya bumili ng comp, 2 valves and drier, tapos bayad lang ako labor and freon. Ok na ang lamig, kaso ayaw mag automatic pag naka idle, kailangan pa ibaba ung manual thermostat sa 1/2 tapos nag high pressure.. So nag suggest sya na palitan namin 2 condenser. Problema ngayon ganun parin, parang mabagal parin mag automatic pag naka idle, pero pag umaandar naman ng mga 60, ok na sya sa automatic.
    #10257
    Specialtikoy,
    Subukan mong lagyan ng trapo sa pagitan ng bar ng 2nd row seat at yung sahig. Minsan dyan nanggagaling yung ingay.
    #10258
    Taz13,
    Pa check mo yung thermistor (yun ata ang tawag nila). Yan ang nag regulate ng idling ng sasakyan.
    Dec 2009
    #10259
    Sa mga naka euro inspired na pajero ask lang po if pati ba yun chrome gutter is painted matt black? And yung side mirrors matt black din ba or body color? Thanks.
    #10260
    You can DIY it or bring it to an upholstery shop like seatmate. The cause is usually a loose bolt. Mine was noisy before until I found that I was missing a nut with one of the chairs. I bought a replacement, screwed it in, secured the seat and now it doesn't really squeak.
    Quote Originally Posted by TAZ13 View Post
    Mitsubishi put that solenoid valve there for a reason. Anyway, I wouldn't know why your compressor isn't automatically running and cutting off. Maybe you should take it to another shop for a 3rd opinion? Not to think that your friend didn't do a good job but it is really hard to find an A/C shop in Manila that does good work.
    Quote Originally Posted by pajero02 View Post
    You're in a Pajero thread man so we'll always answer Pajero. :D
    But I think a brand new vehicle would give you less of a headache than a used one so it really depends on how prepared you are with spending time and money in the next two years for maintenance as the BK will surely need more TLC compared to the brand new MS.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
