Results 10,071 to 10,080 of 14348
- Apr 2010
- 8
April 7th, 2014 10:14 PM #10071Mga sir gud pm salamat nga po pala sa reply ni testament11 regarding sa over heat,dinala ko rin yong sasakyan sa mekaniko nag advice mga sir ng tanggalin yong termostat ok po b yon thanks.
April 7th, 2014 10:50 PM #10072
^pag advice ng mekaniko mo na tanggalin thermostat, huwag ka bumalik doon.
Sent from my Nexus 7 using Tapatalk 2
- Jun 2004
- 476
April 7th, 2014 10:51 PM #10073Dont take the thermostat out of the engine. Solve the real cause of overheating. Baka clogged na radiator or sira na water pump? Baka clutch fan kailangan na refill ng silicone oil or baka naman mahina na aux fan ng rig mo.
Posted via Tsikot Mobile App
- Apr 2010
- 8
April 8th, 2014 05:41 AM #10074Salamat po sir crazy_boy* sir paj4x4 tanong ko nga rin ho sa mekaniko ano reason at kailangan tanggalin ang reason nila ay usually ginagamit lang daw ho ang thermostat sa malalamig na lugar para ma stable yong init dito naman daw po satin eh mainit di natin kailangan salamat po ulit
- Jun 2004
- 476
April 8th, 2014 06:40 AM #10075*rex02 tama si CB wag ka na bumalik sa mekaniko na yan. As I said solve mo real cause ng overheating ng rig.
April 8th, 2014 07:43 AM #10076
Kalokohan yan. May reason bakit nandyan yan thermostat at hindi yan dapat inaalis. Kung sakaling may problema thermostat mo, papalitan mo nalang at wag aalisin. Obserbahan mo ang behavior ng sasakyan mo kung gaano kabilis mag-overheat. Check for leaks sa hose fittings, observe mo yun ingay ng water pump mo, at pacheck mo ang thermostat mo. At higit sa lahat, hanap ka nalang sir ng mas matinong mekaniko.
April 8th, 2014 12:45 PM #10077
Yang thermostat engine temp regulator yan, without it your engine will never reach optimum engine temp. It will affect your fuel consumption. Tsaka at 800petot oem its not that expensive compared to some useless accessories we put in our trucks .. <--- guilty ako dyan.. hehehe
- Apr 2012
- 165
April 8th, 2014 08:25 PM #10078Correct. Agree to the max. One thing that i have learned in this forum with fellow pajero owners is that kung feel mo hindi ka comfortable sa mechanic mo lipat ka lang sa iba. Pwede ka din pumunta kay master - Joseph A.
. I have experienced this myself na 2 na mechanic pinagdalhan ko and iba sila ng sagot sa problema ko. I called Joseph A and scheduled an appointment. Kahit malayo paranaque sulit ang punta ko and til now parang gusto ko bumalik para ipaayos lahat hehe
- Apr 2012
- 165
April 8th, 2014 08:28 PM #10079
April 8th, 2014 08:56 PM #10080
On start-up mag b-blink yung a/t, pero once uminit na nawawala naman. Accdg. Sa mga aussie counter parts naten, draining the atf sump and cleaning the strainer is not enough. Need pa daw i flush out yung nasa atf cooler since around 40% pa ng atf natitira dun...
Thread was made nung 2018 pa po sir.
