Page 310 of 496 FirstFirst ... 210260300306307308309310311312313314320360410 ... LastLast
Results 3,091 to 3,100 of 4959
    Mar 2015
    #3091
    Turuan si dominic ku g pano mag menor!siya lang naman ang humaharurot sa isyu ng SUA eh.sila ni kabayad noli bully
    Oct 2013
    #3092
    Bakit kapag may naaksidente involving Montero e nakareport agad sa ABS kahit saang lupalop pa ng pinas? Tapos SUA agad ang dahilan kahit wala pang imbestigasyon na nangyayari. Sa tingin nyo ba sa isang araw Montero lng ang naaksidente sa buong bansa? Bakit yung ibang aksidente hindi nila nirereport? Bias talaga. Sinisira na talaga nila ang Mitsu.
    #3093
    Wala naman mapapala ang drivers kung SUA or accident ang kanilang e- declare... both is covered by INsurance...
    Babayaran at babayaran pa din ng insurance yan SUA or human error... at yung driver naman magbabayad pa din ng participation fee...
    Pride bro... The favorite "deadly sin"... 😁
    "I cannot lose the last election; I was cheated"
    Sent from my Nexus 7 using Tapatalk
    Oct 2013
    #3094
    24 na lang ang natirang complainant. Akala ko ba 100+ na sila? Natauhan na ata yung iba. Nilunok na lang yung pride nila. Alam nilang magmumukha lang silang tanga pag tinuloy pa nila ang reklamo.
    Aug 2004
    #3095
    For lulz, read Page 8 of the DTI report.
    Where, apparently, according to the DTI expert engineer's theory, not only can outside air ENTER the intercooler through leaks in the intercooler, the moisture in the air will condense due to the intake charge pressure and then flash back into steam in the combustion chamber, causing a rapid increase of pressure inside the chamber, causing the ECU to inject more fuel.*
    So... you have:
    1. Air flowing from the atmosphere, which is at 1 bar pressure, into the intercooler, which is at 2.5 bar pressure.
    2. Fuel injection air metering being done inside the combustion chamber, not at the MAF/MAP sensors like in every other car in existence.
    Bravo. I think we've discovered perpetual motion. :hysterical:
    Next time there's an investigation, can the DTI please hire someone who actually knows how cars work?
    *When water enters the combustion chamber, as it does when you use a water injection kit, the water flashing into steam cools down the charge air, making it denser. In effect, you are increasing charge density by reducing charge pressure. The engineer is probably thinking of a water kettle, where adding OUTSIDE heat increases system pressure. Which is the opposite of what's happening here. Here, he's adding outside COOLING to the system.
    Of course, that would work if air could travel from a lower pressure area to a higher pressure area.
    Dec 2007
    #3096
    So... you have:
    This tells us how lame DTI people are. Can't even conduct a credible investigation🙄. Well, what can we expect.....
    Dec 2015
    #3097
    case closed na. si Noli De castro at Dominic Almelor ang tanungin natin. Lumalabas na alam nila lahat. Sila yung dapat i hire ng DTI as third party expert. Isali rin pati yung comunistang si colmenares. Baka hindi na ambonan ng revolutionary tax.
    #3098
    #3099
    Walang mintis sa TV Patrol ah
    Hmmmm did they try putting it on P pag nag SUA?
    Mag wild pa din kaya engine?
    Nov 2011
    #3100
    wrong post
Mitsubishi Montero Sudden Acceleration Accidents [MERGED]
