Results 3,091 to 3,100 of 4959
December 18th, 2015 12:08 AM #3091
Turuan si dominic ku g pano mag menor!siya lang naman ang humaharurot sa isyu ng SUA eh.sila ni kabayad noli bully
- Oct 2013
- 34
December 18th, 2015 12:21 AM #3092Bakit kapag may naaksidente involving Montero e nakareport agad sa ABS kahit saang lupalop pa ng pinas? Tapos SUA agad ang dahilan kahit wala pang imbestigasyon na nangyayari. Sa tingin nyo ba sa isang araw Montero lng ang naaksidente sa buong bansa? Bakit yung ibang aksidente hindi nila nirereport? Bias talaga. Sinisira na talaga nila ang Mitsu.
December 18th, 2015 12:21 AM #3093
- Oct 2013
- 34
December 18th, 2015 12:28 AM #3094
December 18th, 2015 02:07 AM #3095
For lulz, read Page 8 of the DTI report.
Where, apparently, according to the DTI expert engineer's theory, not only can outside air ENTER the intercooler through leaks in the intercooler, the moisture in the air will condense due to the intake charge pressure and then flash back into steam in the combustion chamber, causing a rapid increase of pressure inside the chamber, causing the ECU to inject more fuel.*
So... you have:
1. Air flowing from the atmosphere, which is at 1 bar pressure, into the intercooler, which is at 2.5 bar pressure.
2. Fuel injection air metering being done inside the combustion chamber, not at the MAF/MAP sensors like in every other car in existence.
Bravo.I think we've discovered perpetual motion. :hysterical:
Next time there's an investigation, can the DTI please hire someone who actually knows how cars work?
*When water enters the combustion chamber, as it does when you use a water injection kit, the water flashing into steam cools down the charge air, making it denser. In effect, you are increasing charge density by reducing charge pressure. The engineer is probably thinking of a water kettle, where adding OUTSIDE heat increases system pressure. Which is the opposite of what's happening here. Here, he's adding outside COOLING to the system.
Of course, that would work if air could travel from a lower pressure area to a higher pressure area.Last edited by niky; December 18th, 2015 at 02:16 AM.
December 18th, 2015 08:13 AM #3096
December 18th, 2015 08:53 AM #3097
case closed na. si Noli De castro at Dominic Almelor ang tanungin natin. Lumalabas na alam nila lahat. Sila yung dapat i hire ng DTI as third party expert. Isali rin pati yung comunistang si colmenares. Baka hindi na ambonan ng revolutionary tax.
Tsikot Member Rank 4
- 2,719
December 18th, 2015 10:11 AM #3098meron na naman SUA?
sapul-sa-cctv-pagbulusok-ng-montero-sa-tutuban
December 18th, 2015 10:28 AM #3099
Walang mintis sa TV Patrol ah
Hmmmm did they try putting it on P pag nag SUA?
Mag wild pa din kaya engine?
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
