Results 331 to 340 of 615
- Sep 2014
- 3
September 15th, 2014 06:58 PM #331kindly send alarm manual 2014 gls v to johnabruzzi2008*yahoo.com thanks in advance...
- May 2014
- 118
September 16th, 2014 01:01 PM #332based sa manual emergency override tawag dyan kaso haven't tried it yet, it says pag kasusi mo mag aalarm sya, so turn ignition key on then press for 5 secs the red button para madeactivate. Maybe the usage of this is when your remote is not functioning anymore (low bat or misplaced)
- Sep 2014
- 8
September 20th, 2014 12:26 PM #333sir pasend din po alarm manual for 2010 montero gls * engr_phaye*yahoo.com.ph
thnx
- Sep 2014
- 3
September 25th, 2014 04:49 AM #334Sir, pa send din po ako ng alarm manual gls 2010 johnaaron4*yahoo.com , Thanks.
September 26th, 2014 03:15 PM #335
Sir, pa send naman ng alarm manual , Thanks in Advance * matias.edwin*gmail.com
- May 2014
- 15
September 26th, 2014 10:35 PM #336Pasend dn po ako mga sir ng alarm manual.. Bgla n lng kasi ng aalarm si teroy kahit tahimik.. as_abad12*yahoo.com, TIA po
- Jul 2014
- 9
September 28th, 2014 10:59 AM #337Thanks po sa pagemail ng manual. Pero I think iba ang manual ng alarm para sa 2014 glx model? Sa number of chirps pa lang iba sa akin.
- Dec 2013
- 2
September 29th, 2014 08:46 PM #338Help! 2014 MS GLX owner here. Car would lock using the keyless entry but would not unlock. Tried both remotes but same result. Noticed that the park lights does not blink when locking the car. Also, the alarm would make the arming sound every 30 seconds to 50 seconds. Not sure how to reset it. Tried pressing and holding the alarm button under the dash and turning the ignition to on. Nothing happened. Grateful for your responses. The only time the arming sound would stop is when I leave a door or trunk open. Thanks for your responses.
September 29th, 2014 08:53 PM #339
- Jul 2010
- 844
September 29th, 2014 09:30 PM #340Pano ang mute sa Alarm ng monty? GLS V user here
Posted via Tsikot Mobile App
high idle RPM at engine start
