Results 1 to 10 of 12
- May 2004
- 903
August 27th, 2020 12:02 PM #11. Ive seen several post in social media that 4n15 consume engine oil, about 1 litter per 3000km. Is this normal or not?
2. Too much blow gas or white smoke coming out of the dipstick. As per casa they say its normal because of newer engine design that have EGR. How much blowby is normal?
3. When opening the oil filler cap there is white smoke and oil. I know you dont suppose to do that but is it normal to have white smoke and oil spitting?
- Jan 2008
- 4,726
August 27th, 2020 12:31 PM #2
August 27th, 2020 02:15 PM #3
When you see some gas from the oil filler with a hot engine it is normal.
Oil consumption
Your concerns point to monitoring/checkinf engine temperatures and thermostat
- Aug 2008
- 498
August 27th, 2020 03:17 PM #4They use a lighter weight oil 5w30 or much lighter,instead of recommended in manual that specifically said that you use a grade/wt oil according to atmospheric temperature. What to expect, pang winter grade gamit. Dami kasi snow dito.
August 27th, 2020 03:38 PM #5
- Aug 2008
- 498
August 27th, 2020 04:13 PM #6Lighter weight oil tends to shear much faster. Tried all the wt from 5w30-15w40. In comparison sa nacocollect sa oil catch can almost a liter sa 5w30 vs 300cc sa 15w40 after 10,000km. Winter oil is no no dito sa klima natin.
August 27th, 2020 04:18 PM #7
- Aug 2008
- 498
August 27th, 2020 04:50 PM #8
- 54,230
August 27th, 2020 04:58 PM #91. in the olden days, 1 liter per 5000 km was still acceptable. that one liter is about what it takes to raise the oil level from the low line to the high line in the dipstick. but nowadays... it might be too much.
2. that's normal. kasi, the seal between piston and cylinder wall is not perfect. meron laging nakakalusot.
3. normal. same explanation as #2 above.
if you want to find out whether the engine will need expensive fixing in the near future, do a compression test.
Ford kasi... it needs a lot of TLC. ;) Kidding aside, I don't know if other turbo vehicles have...
0dometer problem
