Results 1 to 10 of 15
September 29th, 2003 12:37 AM #1
What specific rpm does the turbo of a 4D56 intercooler turbo kick-in? Low pressure or high pressure ba turbo niya?
Thanks.
- Jul 2003
- 579
September 29th, 2003 09:05 AM #3
It starts working around 2K rpm. It does not really kick in, it gradually builds up pressure. Basta sufficient na ang exhaust pressure.
- Sep 2003
- 13
September 29th, 2003 02:49 PM #5Mr. Roydok, you may know this already but I learned from the shop where I had my Space Gear's injection pump overhauled, the injectors in a strada is the most expensive among the mistusbishi diesels. Mine cost Php850/piece but for the strada it costs Php1.4K per piece! for your info.
March 26th, 2011 03:09 PM #7
is the 4D56 engine in the montero sports basically the same as the 4D56 engine in the adventure?
are the parts interchangeable?
- Aug 2010
- 278
March 26th, 2011 04:16 PM #8
March 26th, 2011 09:36 PM #9
the turbo setup and the overhead cams palang, malayo na sila, although they have the same engine code, baka sa seals and engine block lang ang same..
March 28th, 2011 11:37 AM #10
^ strengthened engine parts (piston, rods, bearings din yung sa crdi) as per MMC mismo.
high idle RPM at engine start
