Page 58 of 257 FirstFirst ... 84854555657585960616268108158 ... LastLast
Results 571 to 580 of 2561
    Oct 2009
    #571
    Ask ko lang po when ang next schedule for EB? sana po maka join and maka experience din kami na newbie here...thanks in advance..and thank you sa mga advises sa forum na ito. dami ko natututunan. wag po kayo mag sawa mag advise expecially sa mga bagong tulad namin...salamat po.
    Oct 2009
    #572
    Lancer GLXi A/T 1994 ko wala ng menor. Pag-start nakapalo agad sa 2000rpm, inadjust/pinihit ko na ang servo bypass but nothing happens..sira na kaya ang servo nito? where can I buy this?
    Oct 2009
    #573
    Quote Originally Posted by mge View Post
    timber, my itlog is also gli 95...
    you got pm...
    Bro mge, what's the average fuel consumption of your gli? I think mine is a bit on the high side, my full tank only last 3-4 days of Makati-Binan vise-versa. Average ba yun?
    What do i have to check to see if medyo mataas fuel consumption ko?
    thanks for any advice you could give.
    Oct 2009
    #574
    Quote Originally Posted by char_r View Post
    Please try to check sa banawe and evangelista. ikot ikot lang po sigurado meron replacement nyan. if wala po kayo makita, sa el dorado pasay taft rotonda order basis po if wala sila stock.
    Will definitely check this out. Thanks bro!
    Oct 2009
    #575
    Quote Originally Posted by benxp View Post
    Sir nabili ko po servo ko brand new sa El Dorado pasay taft php8000 only. Naka promo po sila nung binili ko. then labor on installation php500 sa labas lang din ng el dorado marami nagkakabit.. Meron din surplus but my advise is go for the brand new para mas sigurado. by the way, if hindi na ka promo ang servo sa eldorado, this wll cost you 12 to 14k more or less. try nyo rin canvass sa nearby autoparts ng eldorado. hope this can help.
    Oct 2009
    #576
    *char_r
    thanks sir..nakabili ako sa ATCO Pasay ng servo kit 16K (genuine), 10.5K kc ang replacement konti lang difference to go ako sa orig.
    ippkabit ko n mmya sa mekaniko, sna umokey na..
    #577
    Newbie here. Mine is Mitsubshi Lancer 1996 GLI. Ask lang po kung saan makakabili ng bagong rear shock absorber at magkano? Di na kasi kayang magsakay ng 3 sa likod, laging sumasayad kahit hindi lowered. And isa pa po, saan din po ba maganda magpapalit ng carpet ng car...medyo luma na kasi.
    Kung meron sa may Sta. Rosa or Binan Laguna area much better...
    Thanks sa forum....very informative...
    #578
    Quote Originally Posted by nivlax View Post
    Hi! newbie here. got my lancer 96el last month lang. kotse ng boss ko, e nagpalit na siya ng car kaya binili ko na. hehehe.
    Anyway, last weekend binayahe ko siya ng batangas, medyo maganda kasi yung kalsada sa expressway kaya medyo nabatak ko ng konti (around 120 - 130kph). wala naman akong naramdamang problema during my ride. pagdating ko sa bahay, chineck ko ung makina, napansin ko na may stains of oil under the hood, sa may right side. tinanong ko sa mekaniko dun sa amin and sabi nya sa aircon compressor daw yung tagas.
    tanong ko lng, may kinalaman ba yung pagbatak ko sa expressway sa leak sa compressor (kung yon nga yung problem)? or meron pa kayang ibang cause yung leak? thanks in advance. more power!
    ATMM (According To My Mechanic): Ang AC daw ang may maximum tolerable rpm po na pag sumubra ay magka high pressure at malamang bibigay ang compressor. Kaya raw pag ang speed ay morethan 120kph na.. off muna ang AC otherwise bibigay ang AC Compressor.. dahil mahina na ang internal parts nito dahil maykalumaan na.. Maybe sa mga bago pa. di naman umi epekto.. let's see.
    #579
    Hello Itlog owners, still don't have this high performance car but If I have, I will try to convert her pcd 100 into pcd 114 for her rims so that I can fit a 6 spokes VR 15" mags. ANG GANDA SIGURO....Pano kaya?
    Sep 2009
    #580
    Quote Originally Posted by wingman731 View Post
    Brothers! Please help!
    Just acquired a 2nd hand 94 gli. Having problems with a screeching sound when I turn on the AC, nawawala naman when I turn it off. When I turn on the AC pag idle siya wala naman pero after 5 mins. when I rev the engine lumalabas ulit yung screeching while the AC is turned on.
    Kakapalit ko lang AC belt and kakahigpit lang sa kanya. What could be the problem? A friend told me that it could be the idler bearing or the pulley?
    I'm from the south, can CeeJay's handle this type of problem?
    Malamig naman AC ko pero when the screeching starts after a while parang nababawasan ng lamig.
    Saklolo po!
    >bro pg pnplitan m ung bearing check mo shaft na pinapasukan ng bearing dapat di xa worn-out, kung worn-out pabuild-up tsaka re-machine. Pag di mo pinaayos kung worn-out babalik ung ingay nya kahit bgo pa ung bearing. please check dapat nsa 0-0 ung tolerance kapag pinamachine mo para may interference fit xa.......gd luck
