Page 203 of 203 FirstFirst ... 103153193199200201202203
Results 2,021 to 2,027 of 2027
    Quote Originally Posted by ragedo95 View Post
    mga bossing, meron akong lancer cvt gls 2011 at kailangan na palitan yun front break pad ko. Nag inquire na ako sa citi and diamond motors pero parehong out of stock. Any idea or recommendation kung san makaka bili ng OEM na break pad for our lancer? salamat
    bro how often do you change the cvt fluid? ilang liters?
    #2022
    Pasingit na rin ha. Does this model use the same CVT fluid as the older 2006 Lancer CVT? What CVT fluid do you use?
    May 2012
    #2023
    Alam ko nag dagdag yun casa dun nun 40k check ko.
    Mar 2013
    #2024
    tanong lang mga sir,ano bang tawag sa bulb ng tail light ng cedia?tama ba na peanut bulb to tapos double contact? tapos 4pcs pag both tail light assembly yung papalitan?
    Sent from my SM-G920F using Tapatalk
    #2025
    Quote Originally Posted by haxso View Post
    my 2003 used an ordinary two-filament bulb, po. the one the auto parts guys default to, if buyer says he "does not know which one".
    the other two bulbs in the tail light assembly, are an ordinary single filament bulb for the reverse light and another similar one for the signal light.
    i am not sure if there is another version of cedia tail light, that uses peanut bulbs. baka nga meron.
    Mar 2013
    #2026
    oks na po, nakakita ako kagabi ng vid kung pano baklasin yung tail light, madali lang pala, kala ko kasi parang headlight na pagkahirap hirap baklasin. 2 bulbs siya isang W5W(T10 ata) at isang W21/5W(T20 ata). Mura lang pala yung bulbs, 100+ lang inabot ko for both. Ang di ko lang maintindihan, bakit sabay pa silang napundi.
    Thanks sir!
    Dec 2009
    #2027
    Mga pips baka me mga naka experience na sa inyo mawalan ng Park Light, High Beam, Flasher at Wiper spray? Sabi ng electrician ko eh baka Front ECU relay daw. Baka meron ba kayong marecommend na shop kung san makakakuha ng Front ECU relay (MR515500). Salamat sa tulong...
Lancer GLS/GLX CVT 1.6 2009 Owner post naman dito
