Results 1,131 to 1,140 of 2048
- Jan 2013
- 686
May 1st, 2014 10:31 AM #1131Uno Servicio yung pangalan ng shop.. i can recommend personally kse i have first hand experience.. dyan ko pinapagawa yung mga dati kong kotse hanggang ngayon.. Danny Policarpio pangalan ng may ari.. yung shop nya ay pagkalampas lang ng arko ng roxas district along scout chuatoco..
- May 2014
- 3
May 4th, 2014 09:27 AM #1132Same issue sa Montero ko. I have a 2011 Montero GLS. Last, April 27, 2014 I was in an uphill climb about to overtake a very slow bus. My speed tailing the bus was only about 30KPH. When I tried to accelerate the transmission disengaged from "D" with no display at all sa LCD panel though the engine still running. I guess it shifted to N. I tried the manual shift but still no display and not shifting to any gear. When I shifted to P only then the LCD gear display was restored then shifted to D then doon lang ako naka drive forward ulit.
For about 3 times on my way home, whenever I am on full-stop or slowly accelerating I experienced the same issue and resolved it with the same change shift from P to D.
I have it checked with Diamond Motors on April 30, 2014 and they immediately told me that it is a known issue which is the Inhibitor Switch. They said that it is no longer covered by warranty so I have it replaced for Php 5K parts and 2K labor.
This issue is actually quite dangerous particularly when it first happened to me overtaking a bus uphill. This should be covered by a recall with the parts replacement at Mitsubishi's expense.
May 7th, 2014 09:30 PM #1133
Happen to our 2009 strada, it must be the blower fan motor for the aircon, if it stops again try nyo sir pukpokin yung sa ilalim ng glove box para maalog yung motor. The prob with the blower motor is sealed cya it cannot be fixed. So your option is replacment, dito sa bicol it cost 4.5k same sa alterra ang blower motor nya kaya medyo pricey. After mapalitan i tried opening the old blower to see what went wrong, ok pa naman carbon brushes kaso yung stator if not mistaken yung solid sa gitna na uka na sya kaya wala ng kontak sa brushes at madumi na sya dahil sa mga ashes nung carbon, this causes the sudden stop nd go of the blowing of cold air
Hth
Posted via Tsikot Mobile App
May 8th, 2014 10:16 AM #1134
Mga ka-tsikoters need your advise before ko dalhin sa casa, just now lang biglang meron ako naririnig na parang whistling noise sa steering wheel during turns either left or right.
Anu po kaya yung problem nun? Yung level naman power steering fluid nasa max.
May 8th, 2014 10:38 AM #1135
Yung whistling noise b mahina lng? Once na i-steer mo maririnig mo na? Kht nkastop kapa. Saka parang tamad na bmalik ung manibela pag lumiko ka kht mabilis na stuck sya some point kht may buwelo. GLX M/T rin ba unit mo? Ganyan din skin pero dati wala naman yan.
May 8th, 2014 10:51 AM #1136
Chief idolpuge, oo sir mahina lang, oo din sir kapag na steer maririnig, hindi ko sir napansin na tamad bumalik, binabawi ko na kasi kaagad yun manubela. Nun magpark na ako saka ko narinig yung noise. Yup, GLX M/T 2014. Hanggang ngaun sir naririnig nyo pa din yun noise? Oo sir wala din naman ito before, mga 1 1/2 months na yun auto ko. Sa inyo sir gaano katagal na? Napa check nyo di po ba sa casa?
May 8th, 2014 12:13 PM #1137
Pag nadala ko na sa casa baka dis week papacheck ko update kita agad. Skin mag 4 mos na monty ko. Pag nka off yung HU ko mas rinig ang noise lalo na pag off din aircon. Pag park din at mani ubra. Sa reverse nman wala k bang naririnig na parang may tubig sa loob ng shift knob? Like water drops.
May 8th, 2014 01:37 PM #1138
May 9th, 2014 10:46 AM #1139
Update ko lang, sabi ng daddy ko guni-guni ko lng daw yung naririnig ko. Hahahah! :D pagdating kasi sa house wala naman ako nadinig. And na check din ng daddy ko yung fluid & belt ok naman at wala din sya nadinig. Mukhang sahig lang ng parking lot yun nag produce ng sound during turns. Heheh :D
May 19th, 2014 01:29 PM #1140
anybody who has had premature suspension problems with his/her MS GLS?
Just came from the casa, need to replace upper/lower ball joints on one side. Very disappointing kase sobrang ingat na nga sa mga lubak pero heto parin, our unit has clocked a mere 50k, mostly highway driving
May mga kasabay ako na same problem din when i got there, what's worse is kailangan pa maghintay kase wala pa raw available, hopefully within the week lang.
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
