Page 103 of 205 FirstFirst ... 3539399100101102103104105106107113153203 ... LastLast
Results 1,021 to 1,030 of 2048
    Mar 2005
    #1021
    Hello po meron po ako na experience na squealing sound sa 09 Montero ko with 36k mileage. Usually nangyayari siya pag umarangkada. Cleaning lang ba ng mga belts at pulleys ore replace na din po ng belts?
    Dec 2013
    #1022
    Quote Originally Posted by jeffcristobal View Post
    May naka experience na po ba sa inyo mga sir na pag tinatapakan ung gas tapos binibitawan parang naka gas parin for 1 or 2 seconds? Parang delayed
    yup, ganun din sa akin, medyo mabagal bumaba yung rpm, napapansin ko to tuwing galing ako mag drive sa cable linkage accelerator or low tech na sasakyan, lalo na kung manual transmission yung MS mo kadalasan pag apak mo sa clutch in gear shifts naiiwan yung rpm.
    i'm not sure baka setting talaga sa electronics nya na medyo delayed bumaba yung rpm, or baka din ma resolve if mag install ka sprint booster or air filter upgrade ka.
    Dec 2013
    #1023
    Quote Originally Posted by zix888 View Post
    check air filter
    check matting
    sir Zix888, ty nga pala sa EGR plate, by January na lang yung K&N thru LBC na lang ulit, wala na pala sila pasok next week eh.
    #1024
    Quote Originally Posted by jotik-ind View Post
    thank you sir
    Jan 2009
    #1025
    Quote Originally Posted by jmpet626 View Post
    I had the same problem with my 2009 MS 3.2. Replaced aircon and alternator belts (package) but pulleys cleaning only. Problem solved.
    Dec 2013
    #1026
    Sir may nakapag palit na ba ng gas tank and filler neck sa labas ng casa?
    Jan 2013
    #1027
    goodevening mga ka tsikot tanong ko lang yung problema ng montero namen,almost 6 months pa lang pero nangyare na twice parang ang tagal mag start ng monty namen hindi siya yung usual parang 2 sec bago mag start,pansin ko to pag naka ilaw yung fuel gauge,hanggat hindi ako nag papagas eh ganun pa din.pero pag nagpagas na nagiging normal yung pag start ng engine.never ko na experience sa iba naming sasakyan to eh tingin nyo battery ang problema?thanks
    Feb 2014
    #1028
    Mga sir, newbie here.
    Pansin ko lang sa monty namin, bumibitaw yung transmission kapag umaandar. Nawawala yung letter D sa panel. As in walang nakaflash kung san nakalagay yung kambyo kahit nasa D lang naman. Ang natitira lang dun sa LCD cluster, yung trip at odo. Kapag inilagay sa N tapos ibabalik sa D, nawawala naman pero babalik din yung problema moments later. Minsan hindi nasosolusyunan ng pagshift sa N. Minsan kailangan ilagay sa manual mode para magkaron ng Drive ulit. In short, nagnuneutral sya ng wala sa lugar kahit walang movement na ginagawa sa kambyo.
    Mostly city driving kasi nagagamit so baka isa sa factor.
    Pakiramdam ko lang na possible ECU problem. (Not sure so I decided to post here)
    May past issue nga pala yun dati. Yung kinalawang na fuel tank. Napalitan na yung fuel filter and fuel tank under warranty. Mga second week of January napalitan. (I thought I should mention it because it might be a factor)
    Montero Sport 2.5L 4x2 GLS yung unit.
    Thanks in advance sa makakaenlighten sakin sa issue.
    Feb 2007
    #1029
    Pa check nyo sa casa sir. Looks like an inhibitor switch problem...
    Sent from my Nokia 5110 using Tsikot Forums
    Feb 2014
    #1030
    Ganyan din skin 1month old plng monty ko naexperience ko n agad yan. Kadalasan yan pag nka 2nd gear ako sa palagay ko normal lng yan. Sa M/T lng gnyan. Mine is 2014 GLX m/t
    Posted via Tsikot Mobile App
ISSUES FOR THE MONTERO SPORT. Please post them here.
