Results 1,011 to 1,020 of 2039
- Sep 2010
- 53
- Jan 2009
- 31
November 11th, 2013 06:21 AM #1012Wag wd40, belt dressing dapat. tignan mo din yung sa alternator belt baka dun galing,makikita mo kung may black dust from the belt sa alternator. nangyari na din kasi sa akin yan..akala ko pulley bearing kasi kalansing ng metal plus may belt squeaking sound. pinapalitan ko lang yung a/c at alternator belts at nilinis ang pulleys at may kalawang at dumi, kapag di masyado gamit ang sasakyan ay naiipon ang dumi sa pulley. Nawala na yung kalansing at belt squeaking, maaring bumalik ang squeaking sound after few months kasi luluwag yung new belts, i-adjust na lang yun tension para sumikip ng kunti,
- Dec 2013
- 13
December 1st, 2013 05:29 AM #1013mga Sir, ask lg din po ako, pansin ko kc sa MS2014 GlsV M/T ko everytime i turn off the engine there seems to be a buzzing/humming sound sa engine compartment after the engine shuts off, i'm not sure kng saan banda, is it normal? ganun din ba sa inyo? thanks
December 1st, 2013 09:00 PM #1014
December 2nd, 2013 10:50 AM #1015
- Dec 2013
- 13
December 2nd, 2013 08:43 PM #1017
well...after 8k kms on blank EGR, nag check engine light monty ko....what do you think guys seems to be the problem? no limp mode btw...
- Sep 2010
- 53
December 2nd, 2013 09:02 PM #1018
- Jan 2012
- 54
December 14th, 2013 09:37 PM #1019May naka experience na po ba sa inyo mga sir na pag tinatapakan ung gas tapos binibitawan parang naka gas parin for 1 or 2 seconds? Parang delayed
Tsikot Member Rank 1
- Jul 2009
- 4,090
December 17th, 2013 10:24 AM #1020
there's this youtube article, about a 2000s altis, that had a high rpm on cold start (2000+ daw),...
high idle RPM at engine start
