Results 741 to 750 of 2048
- May 2008
- 290
January 6th, 2011 02:09 PM #741This happened to me last december 26 or 27. I intend to step on the brake because of in-coming tri-bike but i realized it is accelerating rather than stoping. but i was quick to realized i am steping on the accelerator and not the brake peddal. Scarry but it happens. Presence of mind is necessary. Ingat pals....
January 11th, 2011 05:33 PM #742
January 11th, 2011 09:06 PM #743
- Sep 2006
- 13
January 12th, 2011 10:14 AM #744Hi, newbie here. Got my montero a month ago. I have a question sana if anybody can help. When I got the montero from Citimotors, yung alarm nya naka valet mode and hindi alam nung SA kung pano sya i-activate. So after reading a lot of forums e I finally manage to make it work. So naka-arm na yung alarm nung car but every now and then e naga-alarm sya even if nobody touched the car. After closing the door and arming it, it will alarm after mga 10 minutes yata and according to the guard ng parking space e alarm daw ng alarm yung car. I tested over and over again, and talagang naga-alarm sya basta basta. Has anybody experience such problem? and sino kaya marunong on how to configure the monty's alarm? btw, I have a 4x2 GLS AT, nakuha ko sya last december 2010 lang.
January 12th, 2011 12:48 PM #745
January 12th, 2011 01:34 PM #746
January 21st, 2011 03:41 PM #747
guys nachecheck niyo ba front foglights niyo?
nagkaroon ng bubbles parang kumulo,naluto sa init yung reflector nung sakin. napalitan na last year ata pero nagkaroon nanaman dito sa ipinalit
nung una stock bulb naman ang nakalagay. ngayon nagpalit na ko pero same watts naman
- Feb 2011
- 51
February 26th, 2011 10:49 AM #748Good day tsikoteers. My monty is a 4x2 vgt AT 2011 model, I noticed that the steering wheel does not go back to straight position after turning right or left or even just by swerving to right or left. Is this normal for rear-wheel drive vehicles? Unlike my old honda city and the honda civic of my sister that you just need to let go of the steering wheel and it will return back to straight position.
February 26th, 2011 04:32 PM #749
Is there a way to manually disable the alarm when the keyless entry goes bonkers? Was at Podium today and the keyless entry refused to activate though the red light was working on the switch. I guess this is because of RF interferance in the mall. When I locked it manually instead, the alarm activated. When I returned, I tried again the keyless switch but it again refused. Unlocked manually, the alarm went off and disabled the ignition... Noticed the same problem with my Vios before, but the alarm doesn't activate when you lock the doors manually.
- May 2008
- 290
February 27th, 2011 11:15 AM #750
I know it's not a real hybrid, but if Suzuki is able to thread the needle and successfully lobby...
Suzuki Fronx
