Results 31 to 40 of 50
August 8th, 2005 11:35 PM #31
4x4 - all wheels get torque from the engine. It's as simple as that.
When you move the small shifter of the Pajero, a combination of actions using the actuators and soleniods powered by vacum and electricity move the gears inside the transfer case so that the torque coming from the flywheel can be sent to both front and rear axles.
- 135
August 9th, 2005 10:45 PM #32ano pala advantage disadvantage pag naka 4x4 yung kotse?
kasi ngayon naka 2dw ako parati pag linagay ko sa 4x4 may disadvantage ba? lalakas ba kain ng gas?
August 9th, 2005 11:33 PM #33
Sa Pajero, 4H is just similar to a RAV4's 4wd (non-adjustable ang RAV4). Sabi ng Mitsubishi around 2% lang ang difference sa fuel consumption between 2H and 4H.
Lagay mo lang sa 2H until you require or anticipate the need for added traction.
- 135
- 135
August 24th, 2005 11:11 PM #35help!
pwede po pa post picture ng solenoid? and saan yung pwesto niya?
di ko taklaga alam itsura... hehe may contact cleaner na ako
- 135
September 3rd, 2005 12:19 AM #36hello. up ko lang po! pwede po pa post ng picture itsura ng solenoid? and saan nakapwesto?
September 3rd, 2005 12:31 AM #37
pwede naman kaso duty ako. Sa linggo ko pa mapopost unless makahanap ka ng engine bay pic, edit ko na lang.
- 135
September 17th, 2005 09:17 AM #38Originally Posted by OTEP
thanks otep! ngayon lang ako ulit naka check tsikot.com,
eto pala mga pics ng engine bay?
- 135
- 135
high idle RPM at engine start
