Results 1 to 4 of 4
- Sep 2011
- 2
September 4th, 2011 02:00 PM #1Mga sir,
help namn about sa galant vr4 1994 mdl sya.
A/T
Super usok nya tapos puti ang labas ng usok nya...
tska sir pag nag cchanger gear ako ng D pra tumatalon sya... or bka kelangan lang hapakan ng diin ung break para d sya tumalon..
1st time ko kc mag automatic e manuaL ako pls help sa mga naka try na nito,,,
and saan mas mura makakabili ng suspension arm evanglista or banawe po... pa pm nlng tnx
- Jun 2011
- 251
September 4th, 2011 09:22 PM #2
September 4th, 2011 09:29 PM #3
Your first problem (white smoke) might be oil getting into the cylinders. This might be because of loose compression due to failed piston rings. Minimum fix might require a top overhaul.
Your second problem might be shift shock. This is a sign of transmission problem. Minimum would be a simple change of transmission fluid and filter. Worst, it might require a full transmission overhaul or swap with a replacement (surplus) tranny.
- Jun 2011
- 251
September 4th, 2011 11:34 PM #4
Xiaomi E-Car
