Results 31 to 40 of 69
- Apr 2004
- 653
February 12th, 2005 10:15 PM #31ganito din balak ko bilhin..kaso maintenance tyak ang sakit sa ulo nito..either bicol o negros ang pagdadalhan ko pagsakaling matuloy negosyo..( sakali lang kasi ilang beses nakong na"sakal" sa negosyo)..
February 15th, 2005 09:10 AM #32Originally Posted by chizcake71
February 15th, 2005 11:23 AM #33
kung repair kit dalhin mo na lang yung assembly and pakabit mo na lang para sure
February 15th, 2005 11:50 AM #34
prob lang kasi ay walang repair kit...di mo alam kung anung vehicle pinagalingan nyan..my experience kasi ganun...wala nagmatch sa local..either:
1.(madugong way)1 by 1 mo bibilhin ang rubber o-rings or
2.(expensive way)buy a hyundai/L3 surplus or refurbished...then you'll have the repair kit easily..
- Feb 2005
- 2
February 17th, 2005 06:19 PM #35anybody interested in buying a Delica-P35W...
kaka-change-oil palang -- fully synthetic.......
Automatic, syempre 4x4, with sky roof, malakas ang aircon,
mukhang bago pa, newly acquired (2005).......
kung sinoman ang interesado, pwede nyo akong tawagan sa
cel# 0920-9268657, pwede rin text......o kaya sa 8156801 loc 388 (ofc hrs. lang)
February 18th, 2005 10:27 AM #36
sir balatak,
Mayrun po tayong classified section. Pls. post your Delica there for maximum exposure. Thanks. ;)
- Feb 2005
- 2
- Jun 2005
- 10
June 23rd, 2005 02:55 PM #38mga sir,
i bought my delica jasper edition a/t last february bubble top no sunroop and sariwa pa.
napansin ko lang sa conversion ay original parin ang rock and pinion nasa right side pero yung convertion ay yung stearing column from left may gear box then may connecting bar to the right & another gear box going down sa right gearbox ng rock and pinion. my question is, is there any difference from fully converted left hand drive rock and pinion?
5-7 km/l diesel consumption medyo malakas para sa akin compare sa other diesel engine compare sa delica ni sir always_yummy. kailangan ko bang pa calibrate?
many thanks.
June 24th, 2005 12:29 AM #39
sir kung ganyang conversion, i think its a best it is....
the rack is stil intact....baka nga may makuha kang repair kit for that..pero kung 1st time, try to bring ALL the rubbers to your suking mits parts dealer sa banawe...kung ala, sa araneta ave.(from banawe), the 1st intersection after araneta-cor.-e. rod(right side immediately after mo makatawid ng stoplight), may tindahan ng gasket dun....virtually, meron sila for all known gaskets, o-rings,etc..
yeah, 5-7km/l is fair enough(if you're a heavy-footer and sticks to 90kph+ on the highwayz..)mine is from 5-10km/l..kung di naman laging maitim na usok(means: mausok parin kahit sa low rpms)..a clean filter, regular oil change will do..pero ask ka din sa experts,ok?
June 24th, 2005 12:06 PM #40Originally Posted by vwscirocco
high idle RPM at engine start
