Page 104 of 105 FirstFirst ... 45494100101102103104105 LastLast
Results 2,061 to 2,080 of 2093
    Dec 2019
    Jun 2011
    #2062
    Naghakot kanina si kapatid ng 260 pcs ng paving blocks. (~900 lbs.)
    Buti short trip lang.
    #2063
    Quote Originally Posted by bxr monkey View Post
    may side view bah?
    para mas appreciated ang lundo.
    Jun 2011
    #2064
    may side view bah?
    Ay wala po Doc, hindi nakuhanan.
    Kasama kaming dalawa, nasa ~1200lbs ang karga kanina. Pasok naman sa ~550Kgs rated payload.
    Jul 2013
    Jul 2013
    #2066
    hmmm, etacs
    saw a conversation on FB this morning and I did some research
    #2067
    hmmm, etacs
    nagpa ganyan na ko. so far, so good! makes you really wonder why di pa ginagawang standard yung speed sensing doorlocks.
    Jul 2013
    #2068
    Quote Originally Posted by coiter View Post
    honestly, nagulat ako na pati welcome light and seatbelt chime were all deactivated.
    #2069
    true. it would've added value at no extra hardware cost. i also appreciate yung side mirror fold/unfold on engine off/on rather than on door lock/unlock. kasi minsan may kukunin ka lang sa loob, di naman kelangan mag unfold yung side mirror.
    Oct 2005
    #2070
    is the expander 4A91 engine, gdi or mpi?
    Dec 2019
    #2071
    Quote Originally Posted by beachbum View Post
    It uses sequential multiport fuel injection system.
    Sent from my SM-N970F using Tsikot Forums mobile app
    Oct 2005
    #2072
    Just to be clearer. Is the fuel injected directly in the cylinder or in the intake manifold?
    Jun 2011
    #2073
    Sa intake manifold.
    Jul 2013
    #2074
    just sharing...
    FYI, Baguio is 1,470 meters above sea level.
    Genting is 1,865 meters
    He said 2nd gear can reach 100kph ..*6000rpm.
    Jun 2011
    #2076
    Okay din itong paglagay ng cruise control sa basic models. Nakaka alis ng pagod mag maintain ng speed sa highways na up and down or kurbada. Mas relaxed mga legs.
    Malauwag skyway at SLEX NB kahapon kaya malaki distances. Kung may proper distance kaya pa din ma adjust sa trapik gamit +/-. Parang naka video game. Lagi lang ready paa mag brake pedal.
    Jun 2011
    #2077
    Malapit na mag 40k unit namin.
    Balak ko pa change ATF. Sabi ni casa drain and fill lang hindi pa daw kailangan palitan ang filter strainer.
    Bale sa 80k pa kailangan palitan ng AT filter strainer?
    #2078
    i do not xpander, but
    what does the howner's manual say, po?
    #2079
    So I looked it up and the owner's manual makes no mention at all of the transmission.
    Maintenance section is page 292 of this PDF.
    Maybe it's in the service manual, maybe it's by mechanic's guesstimate.
    AFAIK changing the filter will require removing the transmission oil pan, so it's probably not something done very often.
    Edit: Found the maintenance schedule. ATF only needs to be replaced at 100k intervals, which will probably include replacement of the filter.
    Mechanic is probably correct in saying the filter doesn't need to be changed right now because even the AT fluid change is way ahead of schedule.
    Jun 2011
    #2080
    Maraming salamat sa links!
    Iyong local generic warranty booklet, ATF change lang na mention sa 45K intervals.
    100k, 60mo. Intervals pala. Nasanay na sa 40k intervals. Sakto din since 5 years na ang unit. ATF change muna siguro, sa next time na ang filter strainer.
All new Mitsubishi Expander MPV!
