Page 655 of 754 FirstFirst ... 555605645651652653654655656657658659665705 ... LastLast
Results 6,541 to 6,550 of 7539
    Nov 2014
    #6541
    Quote Originally Posted by jessgab View Post
    Sample of my DIY From OEM bulb to LED Headlight shots as requested:
    Position Bulb (Eyeline)- Off headlight: Position Lamp1 — imgbb.com
    Lo beam Headlight On & Foglight ON- Med Tint: Headlight shots1 — imgbb.com
    Maganda sir parang original GLS Premium, interested ako sa HL eyeline DRL, paano mo pinalitan yung LED bulb? TIA
    Aug 2010
    #6542
    Quote Originally Posted by ar2roph View Post
    Discuss ko sa tutorial na gagawin ko...kunting tiis na lang..sinisingit ko lang kasi pag may time ako yung pag gawa... pinag iisipan ko pa kasi if babaklasin ko ulit para lng pakita s inyo yung mga dapat gawin...
    Aug 2017
    #6543
    For GLS/GLX model only:
    *sa mga naghihintay sa tutorials kunting tiis na lang po..inaayus ko pa kasi mga ënglish words ko s docs...
    Nice eyeline bro.wala bang moist after upgrades. Hope matutunan ko yung tutorial mo bout eyeline. [emoji81]
    Sent from my iPhone X using Tapatalk
    Aug 2010
    #6544
    Quote Originally Posted by montro View Post
    I don't open my headlight unit bro. I just replace it the position lamp with better light output. I posted already here the LED that I used. My Eyeline is rhe same function on OEM not DRL but it looks like only.
    I dont want also the idea of opening the headlight just to insert the LED tube and rewire it for DRL like on Premiun. WHY?
    a) If that DRL on eyeline busted it is very hard to replace. You will reopen again your HL unit.
    b) Opening HL unit need seal and resealing process so that HL unit will not be moist inside, need skills here for process. Watch youtube on how they do it.
    Aug 2010
    #6545
    Aug 2010
    #6546
    Aug 2017
    #6547
    Would you mind bro if you share store/shop where you bought those led lights. My HL are upgraded already and only looking for eyeline,position lamp and FL upgrade for out of town used and mountain used as well.[emoji23]
    Aug 2010
    #6548
    Back read pg.652 bro.
    Lazada for foglamp dual color
    Galleon.ph for Position Lamp and Headlamp
    Aug 2017
    #6549
    Do you have a link sa novsight h8 sa FL. Cant find sa lazada.thanks
    Aug 2010
    #6550
    Novsight H11 H9 H8 LED Headlight Bulb Kit Low Beam Fog Light 8LM Dual Color - intl | Lazada PH
    currently it is out of stock.
    Try to buy other model for dual color and reversible heatsink...remember the space on the the right side (facing car) for foglamp has not enough space to fit the LED, that is why i bought this type of LED (w/ reversible heatsink).
    Or try to PM on fb or find there store and ask them:
    Marc Laurence Rafinan Destreilles
    HIDRetrofit.net
    They are offering this retrofit and upgrade with free installation BUT of course the price is high, almost x2 or x3.
2016 Mitsubishi Montero
