Page 642 of 754 FirstFirst ... 542592632638639640641642643644645646652692742 ... LastLast
Results 6,411 to 6,420 of 7539
    Jul 2006
    #6411
    Quote Originally Posted by montro View Post
    If you want luggage tray for montero 3rd gen. Check import elements 4.4k. Sa slipstreamph 5.8k not exactly sure pero closed to 5.8k.
    Sent from my iPhone X using Tapatalk
    thanks, but have you or any of you here gotten one? i'm undecided kasi which one to get.
    i'm concerned more on water leaking (ex. dive bag/gears, groceries, sports equipment, etc). part of me wants to get the 5-pc tray para naka fix na sa car, and anytime pwede parin magamit yun 3rd row seats; and there's this part rin na the 1-pc tray seems more practical because it looks more water leak safe, yun lang i have to remove or make sure to set it on when sure na kailangan; then there's the matter of not being able to use the 3rd row seats on demand.
    Aug 2017
    #6412
    Quote Originally Posted by twinkiddoe View Post
    i'm concerned more on water leaking (ex. dive bag/gears, groceries, sports equipment, etc). part of me wants to get the 5-pc tray para naka fix na sa car, and anytime pwede parin magamit yun 3rd row seats; and there's this part rin na the 1-pc tray seems more practical because it looks more waterproof safe, yun lang i have to remove or make sure to set it on when sure na kailangan; then there's the matter of not being able to use the 3rd row seats on demand.
    The cargo tray is fitted on the back of your 3rd row seat,when you fold down the 3rd row you'll see how fitted it was.as per slipstream it is waterproof. Try to look the post of slipstreamph they have a closer angle what it looks like when 3rd row folded down with cargo tray. In import elementz it's almost 1k cheaper same oem. You can still use 3rd row seats even it is fitted already.
    I don't have one, budget permitted.hehe
    Mar 2005
    #6413
    Hello, plano ko po palitan yung head lights ng GLS ko to LED na XHp70 pati na din yung sa fogs. Ano po yung bulb type ng head lights and fog lights for the 2018 GLS?
    Mar 2003
    #6414
    Quote Originally Posted by jmpet626 View Post
    I want to change them also but wala pa ata here.
    Aug 2009
    #6415
    I see Jeff Tan, owner of that shop in Araneta, posting bulbs for the 3rd gen monty on his page.
    Dec 2017
    #6416
    If you're not using much the 3rd row seat then get the 1 piece tray since it's a whole piece and there's no gap in between for water to pour down on the carpet. But if you're using the 3rd row more often then it's more practical to get the 5 piece set. You'll never have to remove it and will protect the back seat even when inclined. The only downside I'm seeing are the small gaps in between the 5 piece construction, water might penetrate into it.
    Sep 2016
    #6417
    hello po. just got our unit last tuesday at citimotors makati but lately ko lang napansin ung door sidings ko ay parang napahiran ng ewan at nagiba ang kulay. hindi ko siya napansin nung kinuha ko kasi medyo madlim sa releasing area ng casa. any advise po kung paano tanggalin ito. natatakot lang po ako baka mamaya maging permanent na po ito. itinawag ko na sa ahente pero hindi pa ako binabalikan. salamat po.
    Photobucket
    Nov 2007
    #6418
    Quote Originally Posted by 1bart View Post
    Photobucket
    Mukhang napahiran ng may oil or unknown chemical.
    I suggest you wipe it off with a damp cloth with mild soap first. Try it first sa small area and plastic part first
    Sep 2016
    #6419
    Quote Originally Posted by JJB View Post
    ang duda ko nga sir napahiran ito ng pamunas na may tire black. very frustrated lalo pa at naiuwi ko na dito sa province namin. pwede po kaya palitan itong sidings ko? salamat
    Nov 2017
    #6420
    hinawakan mo ba kung malangis?
2016 Mitsubishi Montero
