i had my jazz before retrofitted by Gary Q, the quality is superb, light output was outstanding, very clean and the cut off was very good, after sales service was good too. i previously had dark tints on the jazz that's why i had the retrofit done, but afterwards the improvement was significant but not to the point that i felt confident. so i stripped off the tint to clear and thats when i got the significant improvement in terms of visibility. if i had done that earlier on, (before the retrofit), i think i would have already been sufficient.
now with the monty, i went straight for the clear tints, visibility at night is superb and i feel very confident to drive at night. I guess upgrading to better bulbs (HB3, H11), will even improve my visibility at night, that would be more than enough lighting upgrade for my needs. this route will be less expensive than a retrofit.
Have you guys done something with the splash pad at the 2nd row door, dirt usually gets in to that part and it's quite hassle to clean?
wag mo ng basehan sir yung Light indicator ... kumakagat naman sya agad sir.. ganyan din ako dati..akala ko hanggang walang ilaw or di pa na release ang indicator light at dun palang mag engage.
pag nasanay ka sir... ok sya... yan na din kase ang trend ng mga high end na sasakyan now.
It's a common experience with those who have Vkool tints for their satnavs to lose signal, especially those portable models whose antennas are built-in. It probably has to do with the reflective material Vkool uses to keep the interior cooler than other brands.
A workaround would be to buy an external antenna.
