5. Curtain airbags
6. Side airbags
these are the ones that convinced me to go for the Prem variant.
most of the other features can be added using aftermarket parts like DRL, leather seats etc but i can't add airbags later![]()
5. Curtain airbags
6. Side airbags
Hi, new here
I would like to ask kung ano sira if di umiilaw yung side mirrors. As far as I know, if mag left/right signal, pag ilolock yung doors, and nakahazard, dpat iilaw yung side mirrors. Recently natupi kasi yung left side mirror nadali ng another car pero niretract ko pra bmalik sa dati kaso di na sya nagilaw. What should i do?![]()
Question pala, minsan while engine off, yung brake pedal cannot be depressed. So pag press ko sa engine start, acc on lang muna, isa pang press para mag engine on, dun palang lalambot yung brake pedal.
Anong reason for this?
Yep it's pretty normal for modern cars. Our brake system is equipped with hydrovac assited brake system. Meaning it needs vacuum to have a softer push to the pedal and creating a much stronger plunger hydraulic force to stop the car. Vacuum is only achieved when the engine is running either from a slave vacuum pump piggyback *Alternator or from the intake manifold. Normally if you don't have any leak on the system the vacuum is good for one use of vacuum assisted brake without engine running. If you turn off the engine with your foot off the brake pedal it should retain the vacuum good for one use, if it doesn't then there's a leak on the vacuum hoses. or the brake diaphragm.
Anyone here also experienced the steering issue(alog/uga) that was mentioned here before? Been reading the jerky transmission issue of the new fortuner and someone mentioned that in thailand some pajero sports owner had the same steering issues. Also mitsubishi acknowledged the problem.
I asked my father about this issue since he's the one driving most of the time. And yes, may alog/loose feeling kapag inuuga mo. Pero inunlock daw niya and diniin niya yung steering wheel pababa then locked it again. After that wala na yung alog. I don't know if this is the same issue, but so far wala ng alog sa steering
i experienced the power steering alog feeling. Hinid ung steering wheel ung may alog but everytime you make hard turns or u turns ypu can feel some kind of vibration that's originating down. During my 5K PMS I brought this up to the SA and he advised me to go the the Warranty service. So we perform Quality Evalation so they have this form wherein there'a a list of things they need to perform while driving. The engineering itself driving my monty felt the power steering alog/vabtation during turns. It's been a month since we had the test and I made a followup last week and they said Mitsubishi plant in sta rias. Mitusu thailand and japan are aware and and they are investigating whats possibly causing this.
Hello, meron na ba dito napa disable retract ng side mirror when locking / unlocking ng montero? Its just nakakaawa kasi marinig un mirror motor lalo pag may kunin lang sa loob 😁
Yung monty rin ng mother ko may alog yung steering and on the highway it veers slightly to the right. Ramdam yung alog sa steering kapag sa cemented roads lalo na kapag may small potholes. Tipong kapag binitawan mo yung steering wheel at dumaan ka sa concerete road gumagalaw yung steering wheel (clockwise and counter-clockwise) hindi pa namin napapa check sa casa kasi hindi pa kami nakaka 1k odo.
Yung humming sound, I think aircon ito and normal. Kanina naka neutral ako sa traffic, napansin ko sya. Subtle naman. If I open the window, di ko na sya ring since mas malakas na engine noise. Checked google and apparently, common ito even other brands
