Results 3,091 to 3,100 of 7539
- May 2006
- 280
November 10th, 2016 10:58 PM #3091Ipad runs fine at 9.3.5, my phone 10.1.1 ayaw.
Assuming you did it correctly dapat gagana yan
1. From hu press wifi
2. From ios device connect to mitsubishi wifi
3. Slide from bottom to up to access airplay mirroring tab, press it
5. Enjoy mirroring
Oh i removed the micro sd of the navi since i find it annoying (i use waze anyways)
And more importantly to lessen load on the hu. I noticed nag lalag yun hu dati when i had it inside and no way to off it. Just make sure you set time and date not dependent on navi otherwise when you take out the card wala ka time and date na tama
November 10th, 2016 11:34 PM #3092
- May 2006
- 280
November 11th, 2016 02:48 PM #3093
- May 2006
- 280
November 11th, 2016 02:55 PM #3094like you i hate the aftermarket alarm mitsu installed aside from the real factory keyless entry system. either way, if you read the alarm manual kaya dapat to do a silent unlock and lock. however i cannot seem to change its settings, winterpine must have locked it or something. either go to them to have settings changed, or just remove the fuse for the alarm para tumahimik. i'm thinking of removing the fuse.
the blue light can be turned off, mine upon release was also on all the time. valet mode is on, so follow the instructions in the alarm manual, i was able to turn it off.
- Aug 2016
- 76
November 11th, 2016 09:50 PM #3095Sana pede i-avail yung special edition accessories package ng meron ng montero...
Pure Excitement at Zero to 24 - Mitsubishi Motors Philippines Corporation
- Aug 2012
- 346
November 12th, 2016 10:59 AM #3096planning to replace the stock horn, is the BOSCH EUROPA SILVER or PIAA SUPER BASS HORN plug and play compatible or it still need splicing and relay? TIA
- May 2010
- 39
November 12th, 2016 12:39 PM #3097Hi guys,
Can you share how much you spent for your 5k and 10k PMS? Been having a hard time searching the other PMS thread for this info. Thanks!
- Nov 2016
- 37
November 13th, 2016 07:24 PM #3098
- Nov 2016
- 37
November 13th, 2016 07:30 PM #3099Question po. Kanina driving pauwi nung nag reverse po ako, lumabas sa monitor is "No Signal Detected" walang view ng cam. Ano po kaya ang problem nun? May naka experience na ba? tapos try ko ult after 20mins drive, working na ulit.
- Nov 2016
- 37
November 13th, 2016 07:34 PM #3100Another newbie question po. When turn off napo ang engine and hindi mo nilock yung car. mag auto lock po ba ito? minsan kasi napansin ko nag autolock sa garage namen, pero minsan tintry ko sadyain at hintayin ang tagal na hindi pa din nag auto lock. Thanks po
Lol daig pa mismo ng ford na may surplus parts mula sa mga katay o parts-out na units kahit papano.
China cars
