Page 310 of 754 FirstFirst ... 210260300306307308309310311312313314320360410 ... LastLast
Results 3,091 to 3,100 of 7539
    #3091
    Quote Originally Posted by EsYuBi View Post
    Sir mine is running with V 9.3.4 iPhone 6+ connected na sa wifi ng mistu pero walang reaction yung screen ng head unit. Meron bang kelangan i On or something sa phone settings? thanks
    Ipad runs fine at 9.3.5, my phone 10.1.1 ayaw.
    Assuming you did it correctly dapat gagana yan
    1. From hu press wifi
    2. From ios device connect to mitsubishi wifi
    3. Slide from bottom to up to access airplay mirroring tab, press it
    5. Enjoy mirroring
    Oh i removed the micro sd of the navi since i find it annoying (i use waze anyways)
    And more importantly to lessen load on the hu. I noticed nag lalag yun hu dati when i had it inside and no way to off it. Just make sure you set time and date not dependent on navi otherwise when you take out the card wala ka time and date na tama
    Nov 2007
    #3092
    Quote Originally Posted by balongbalong View Post
    5. Enjoy mirroring
    Thanks for the tip re the time and date on the sd card
    #3093
    Quote Originally Posted by jazoom View Post
    Thanks sa mga tips guys, will try to adjust the settings later.
    Napansin ko din yung left side speaker nawawala paminsan minsan at first akala ko naka sound surround haha hindi pala busit, pano ba ayusin yun?
    first off, you sure you are not in reverse when you noticed na nawala yun sound? engaging reverse will attenuate the radio volume till you put it back to drive.
    also is it left front and rear? or left front only?
    #3094
    Quote Originally Posted by sprockets View Post
    Hello fellow Monty owners,
    Newbie here with some questions, coming from an all analog workhorse(fuego '99) this one is kind of overwhelming. I did read the manual and is slowly digesting it... Here is a list of my questions, hope you guys can help me out.
    1. Can the auto folding side mirrors be disabled?
    2. Can the audible beep(lock) and beep-beep(unlock) sound of the alarm turned off?
    3. Can that blue light(alarm) be turned off? I followed the instructions somewhere here to press that red button under but no go..
    4. Can the daytime running lights be turned off?
    Got the base GLS model as it is the one with the most discount.
    like you i hate the aftermarket alarm mitsu installed aside from the real factory keyless entry system. either way, if you read the alarm manual kaya dapat to do a silent unlock and lock. however i cannot seem to change its settings, winterpine must have locked it or something. either go to them to have settings changed, or just remove the fuse for the alarm para tumahimik. i'm thinking of removing the fuse.
    the blue light can be turned off, mine upon release was also on all the time. valet mode is on, so follow the instructions in the alarm manual, i was able to turn it off.
    Aug 2016
    #3095
    Sana pede i-avail yung special edition accessories package ng meron ng montero...
    Pure Excitement at Zero to 24 - Mitsubishi Motors Philippines Corporation
    Aug 2012
    #3096
    planning to replace the stock horn, is the BOSCH EUROPA SILVER or PIAA SUPER BASS HORN plug and play compatible or it still need splicing and relay? TIA
    May 2010
    #3097
    Hi guys,
    Can you share how much you spent for your 5k and 10k PMS? Been having a hard time searching the other PMS thread for this info. Thanks!
    Nov 2016
    #3098
    Quote Originally Posted by francism171 View Post
    Hi guys,
    For 1K PMS na din po please share info. planning tom for my 1k pms po sa Mitsu Las Pinas.
    Nov 2016
    #3099
    Question po. Kanina driving pauwi nung nag reverse po ako, lumabas sa monitor is "No Signal Detected" walang view ng cam. Ano po kaya ang problem nun? May naka experience na ba? tapos try ko ult after 20mins drive, working na ulit.
    Nov 2016
    #3100
    Another newbie question po. When turn off napo ang engine and hindi mo nilock yung car. mag auto lock po ba ito? minsan kasi napansin ko nag autolock sa garage namen, pero minsan tintry ko sadyain at hintayin ang tagal na hindi pa din nag auto lock. Thanks po
2016 Mitsubishi Montero
