Page 266 of 270 FirstFirst ... 166216256262263264265266267268269270 LastLast
Results 2,651 to 2,660 of 2693
    #2651
    Quote Originally Posted by daywalker21 View Post
    Additional question lng po, just in case biglang tumirik yung Montero Sport GLS variant (Automatic Tranny), is there a a way to shift it to nuetral like its smaller brother Xpander?
    most ATs have a button next to the AT stick, that can be depressed so that the stick can be moved.
    it's in the howner's manual siguro.
    #2652
    That is correct doc.
    However, generally you can just push it from D to N (?).... That's how it is in our AT rides....
    #2653
    i was thinking kasi, that TS wanted to pull the key out of the car, and then push the car. or something like that.
    because that's what we do, in the parking lot. "urong-sulong game", only bigger.
    the travails of those who squeeze themselves in a small parking lot.
    Jul 2014
    #2654
    Patulong po. Anu po kayang problem if may “click click click” sound sa engine while in cold start? Gen2montero. Thanks in advance po.
    #2655
    Quote Originally Posted by kamote25 View Post
    Should be about normal for an ageing diesel engine...
    #2656
    is it before the engine even cranks?
    it can mean anything, po, depending on one's fertile imagination.
    a recording of the actual sound would be appreciated.
    Apr 2012
    #2657
    nomally may ticking sound after switching off the engine. one is yung sa EGR kapag nagsara yung valve. ano ba yung cold start? putting the ignition key to on position lang at hindi paandarin yun engine? or pagkaandar?
    Dec 2012
    #2658
    Need your help bros.
    Where can I buy a CR1616 battery for our remote controller? Tried ACE, True Value, National Bookstore and Japan Homes/Daiso, - no luck..
    Thanks!
    hi you can buy in harisson plaza malate
    2nd floor Workstation ata ung hardware na un
    at the entrance left part
    35P iirc each
    kya isang banig 10pcs na kinuha ko
    mtagal nmn expiry at new stock
    kc 2mos ago kinuha ko nkdisplay
    den kareplenish lng nila new
    fyi
    it is energizer
    kc experienced using different brand
    from Ace same size cr1616
    pero didnt function well
    hope malapit ka dun sa harison
    Aug 2016
    #2659
    2015 Fortuner G or 2015 Montero GLSV?
    Sent from my ALP-L29 using Tapatalk
    Jul 2014
    #2660
    Thanks po monty_GTV, sorry for confusing question po. Pero pagkaandar po ito. Pero after mga 3-5mins idle run, wal npo yung “tik tik tik” noise. Parang noise from vave;not sure. Hirap naman sa casa itanong kaagad kase baka sabihin T-Belt replacement kaagad. Just 65K km odo only. Normal lang po kaya itong noise nato? TIA
2014 mitsubishi montero
