Mga sir normal po ba yung parang may dumudulas na sound pag apak ng accelarator ng dahan dahan galing full stop tapos pag tumatakbo na nawawala naman. Minsan naman po walang sound. Salamat.
On a normal system, electric current flows from a positive terminal to a negative terminal through the car body. But there are much resistance at connectors of body, engine and transmission. The resistance disturbs this flow of electricity to a degree that electrical components such as computer, lamp and spark plugs cannot perform at their peaks. In order to get the highest Performance out of any automobile, it is necessary to achieve a maximum electricity flow with the least resistance along its electrical circuit. In short, a grounding system does to your electrical circuit like a high Performance Intake & exhaust system does for the gas. We believe such system is the basic of all tune-up if you want to unleash the maximum Performance of your car.
While making sure that the operational circumstance is the same, the below table indicates a 7.7% of total resistance which originates from the car body & the same 7.7% of battery voltage which is being wasted due to the absence of a grounding system.
The Grounding System can achieve an extreme improvement on electricity flow and stability by providing a direct ground path from the body, chassis and engine components to the battery negative.
This theory has been known & such system has been used in the racing world for years. Since 1.5 years ago, it has become the hottest modification performed by car enthusiasts in Japan. Its effect on automobile has been proven by dyno tests again and again.
- Faster engine start-up - You can feel the difference even with A/C on and at maximum fan speed. This system reduces the loss of electricity to nearly zero at ignition coil and produces better ignition spark.
- Stable idling - You will hear your car engine noise quieter than before.
- Throttle response - System installed. They indicate a higher torque & horsepower gain. Car used for this dyno test was a Lancer Evolution VI. A max. horsepower gain of 5hp and up has been achieved on a Honda Integra TypeR.
Or read the whole transcript here:
Hyper Ground System – by Sun Automobile :: Sigma Automotive
Bili ka lang ng hks grounding kit worth 700 to 1000 puede ikaw ang mag kabit o pakabit mo kay zix. Bale 6 to 5 cables to ground sa auto yung alternator, throttle controller, engine block, cylinder head, firewall at transmission block
Yung grounding kit nabili ko sa autopromotorz (APM) din yan sa mga ibang shop tulad jdm, etc o sa banawe
parehas ba nito yan, big 3 upgrade na tinatawag?
1. Battery negative to chassis
2. Battery positive to alternator post
3. Engine block to chassis
wala rin ako niyan pero gusto ko rin maglagay...![]()
Para lang sa ground (negative). Yung positive to alternator mag short ang auto kasi yung body ng alternator ay ground o negative pag nirekta mo sa positive sa battery mag weld yan. Puede naman sa alternator to positive ng battery terminal pero wag kakabit sa body ng alternator. Tingin ko yung no 2 ay para volt stabilizer.
Imagine mo na lang sir sa stock na isa lang nakakabit sa body as ground. Paano kung lumuwang ito and becomes loose? Compared to having a grounding kit na parang octopussy. Ang distribution ng elect circuit ay uniform at stable. Una kong mod lagi is grounding kit, followed by horn upgrade, and so and so...
backread mo lang sir, nasa previous page lang...
grounding is a must- have / major mod, and sir smuiv's posts are very informative.
grounding is a must- have / major mod, and sir smuiv's posts are very informative.![]()
^ or kung ayaw mo mag backread, tanong nyo kay mr google sir
Makikita nyo rin na nasa internet na mga impormasyon na yan, gaya ng naipost sa taas.
Grounding kit is on the list, wala lang time gawin. ;)
