Results 2,001 to 2,010 of 2693
Tsikot Member Rank 1
- Jul 2009
- 4,090
- May 2014
- 118
January 8th, 2015 05:52 PM #2002my TV stop working
hope lost connection lang sasabay ko na lang pa check sa 5k PMS ko, puede kaya itrade in yun para palit ako ng skytv, bossing zixx pm mo naman ako price? tia
January 8th, 2015 07:32 PM #2003
guys help naman, san located transmission ECU at OBD port ng montero?
January 8th, 2015 07:54 PM #2004
January 8th, 2015 08:05 PM #2005
January 8th, 2015 10:43 PM #2008
January 8th, 2015 10:45 PM #2009
January 8th, 2015 10:54 PM #2010
eto lang nakita ko sir
puede mo rin PM si zix888 kabisado nya yun
Montero, Montero Sport
APPLICATION
TRANSMISSION APPLICATION
Montero Sport 2WD ............................................ R4AW3
Montero & Montero Sport 4WD .................................. V4AW3
CAUTION: Vehicle is equipped with Supplemental Restraint System (SRS).
When servicing vehicle, use care to avoid accidental air bag
deployment. SRS-related components are located in steering
column, center console, instrument panel and lower panel on
instrument panel. DO NOT use electrical test equipment on
these circuits. If necessary, deactivate SRS before servicing
components. See AIR BAG SERVICING article in APPLICATIONS &
IDENTIFICATION.
DESCRIPTION
Automatic transmission is a 4-speed electronically controlled
transmission. Solenoids that control shift changes are located in
valve body. Solenoids are controlled by a Transmission Control Module
(TCM). TCM receives information from various input devices and uses
this information to control shift solenoids for transmission shifting
and lock-up solenoid for torque converter lock-up.
An Overdrive (OD) switch is mounted on the shift lever. When
OD switch is depressed to ON position, transmission will shift into
4th gear when shift lever is in "D" position, and OD OFF light on
instrument panel will go off. When OD switch is released to OFF
position, transmission will shift into 3rd gear, and OD OFF light on
instrument panel will illuminate.
A pattern select switch is located near shift lever on center
console. Pattern select switch contains a NORMAL and a HOLD operating
position. When pattern select switch is depressed (HOLD position) with
shift lever in Drive position, transmission starts in 2nd gear.
Upshifts and downshifts will occur at a higher vehicle speed than with
switch in NORMAL position. See MITSUBISHI R4AW3 & V4AW3 OVERHAUL
article. Indicator light on instrument panel indicates pattern select
switch is in HOLD position.
Transmission is equipped with a shift lock and key interlock
system. Shift lock system prevents shift lever from being moved from
Park unless brake pedal is depressed. Key interlock system prevents
ignition key from being moved from ACC to LOCK position on ignition
switch unless shift lever is in Park. See MITSUBISHI SHIFT LOCK
SYSTEMS article.
I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
Mineral , semi synthetic or fully synthetic?
