Page 201 of 270 FirstFirst ... 101151191197198199200201202203204205211251 ... LastLast
Results 2,001 to 2,010 of 2693
    #2001
    Quote Originally Posted by the_mechanic View Post
    hi sir harold13. Montero's optitron (gauge appearence), lights are off even naka start na yun engine, unlike other cars na kapag nag-on, illuminated na agad yun gauge mo. On montero's case nagagawan na ng paraan para well-lit na agad yun gauge, which normally done by the master himself, sir zixx. (correct me if im wrong sir zixx)
    +1 sir the_mechanic
    #2002
    my TV stop working hope lost connection lang sasabay ko na lang pa check sa 5k PMS ko, puede kaya itrade in yun para palit ako ng skytv, bossing zixx pm mo naman ako price? tia
    Dec 2009
    #2003
    guys help naman, san located transmission ECU at OBD port ng montero?
    Jan 2009
    #2004
    Quote Originally Posted by miko101130 View Post
    yung obd port try mo dito
    Driver's side, underneath dasboard,between the driver-side door and steering column area.
    Jan 2009
    #2005
    yung transmission ecu baka nandito, PM mo din si zix888 alam nya
    Jan 2009
    #2006
    eto picture
    Jan 2009
    #2007
    AUTOMATIC TRANSMISSION - Transfer-ECU
    Dec 2009
    #2008
    Quote Originally Posted by smuiv View Post
    yellow yung connector nyan module na nandyan. dalawang set ng molex connector.
    kung yan ang ECU ng transmission, nasan ang sa airbag module?
    Jan 2009
    #2009
    tignan ko sir kung may diagram hehe
    Jan 2009
    #2010
    eto lang nakita ko sir puede mo rin PM si zix888 kabisado nya yun
    Montero, Montero Sport
    APPLICATION
    TRANSMISSION APPLICATION
    Montero Sport 2WD ............................................ R4AW3
    Montero & Montero Sport 4WD .................................. V4AW3
    CAUTION: Vehicle is equipped with Supplemental Restraint System (SRS).
    When servicing vehicle, use care to avoid accidental air bag
    deployment. SRS-related components are located in steering
    column, center console, instrument panel and lower panel on
    instrument panel. DO NOT use electrical test equipment on
    these circuits. If necessary, deactivate SRS before servicing
    components. See AIR BAG SERVICING article in APPLICATIONS &
    IDENTIFICATION.
    DESCRIPTION
    Automatic transmission is a 4-speed electronically controlled
    transmission. Solenoids that control shift changes are located in
    valve body. Solenoids are controlled by a Transmission Control Module
    (TCM). TCM receives information from various input devices and uses
    this information to control shift solenoids for transmission shifting
    and lock-up solenoid for torque converter lock-up.
    An Overdrive (OD) switch is mounted on the shift lever. When
    OD switch is depressed to ON position, transmission will shift into
    4th gear when shift lever is in "D" position, and OD OFF light on
    instrument panel will go off. When OD switch is released to OFF
    position, transmission will shift into 3rd gear, and OD OFF light on
    instrument panel will illuminate.
    A pattern select switch is located near shift lever on center
    console. Pattern select switch contains a NORMAL and a HOLD operating
    position. When pattern select switch is depressed (HOLD position) with
    shift lever in Drive position, transmission starts in 2nd gear.
    Upshifts and downshifts will occur at a higher vehicle speed than with
    switch in NORMAL position. See MITSUBISHI R4AW3 & V4AW3 OVERHAUL
    article. Indicator light on instrument panel indicates pattern select
    switch is in HOLD position.
    Transmission is equipped with a shift lock and key interlock
    system. Shift lock system prevents shift lever from being moved from
    Park unless brake pedal is depressed. Key interlock system prevents
    ignition key from being moved from ACC to LOCK position on ignition
    switch unless shift lever is in Park. See MITSUBISHI SHIFT LOCK
    SYSTEMS article.
2014 mitsubishi montero
