Page 129 of 269 FirstFirst ... 2979119125126127128129130131132133139179229 ... LastLast
Results 1,281 to 1,290 of 2690
    Jul 2014
    #1281
    *fleettkr, sir, very likely na drained na yung battery ng sasakyan. All you can do is detach the battery, bring it to a battery dealer/service center or an auto electrical shop and have it recharged for around 50 pesos or less. The dealer would be in a better position to tell you the condition of your battery kung pwede pa or hindi na.
    kapag ok na, ikabit mo na lang uli at ugaliing i-warm-up yung engine at least 15mins everyday.
    Jul 2014
    #1282
    Quote Originally Posted by Bengbeng View Post
    Pero bro assumption ng casa sa mga cel due of dirty or may water fuel filter nila mostly petron diesel gamit. Pero never tried petron dahil may unioil naman samin. Unioil na monty ko eversince.
    Sir, now I feel guilty for filling-up with petron... hehehehe
    pero next time, i'll make the extra effort of using either unioil or seaoil...
    #1283
    OT:ok ba tayo gamit ng methanol/water injection? I just saw it at speedlab's website. Is it more beneficial over other monty mods? Thank you guys.
    #1284
    Quote Originally Posted by BMGregorio View Post
    *Sir prince777 & playplugg, maraming salamat sa immediate feedback...
    I got my unit sa Mitsu Caloocan and Petron was the most convenient gas station in my way that I got to para magpa full tank. I'll keep your suggestions in mind, medyo out of the way lang kasi sakin mga stations ng unioil and seaoil pero if it's what's best for my monty, might as well make the effort...
    I'll also try to get in touch with Sir Zixx888 to find out more about his stuff too, mukhang he has a lot to offer to keep my monty in tip-top shape...
    As for your suggestion regarding using the 4x4 transmission, i think you're right pero baka yung 4H lang magamit ko since the manual doesn't recommend using the 4HLc & 4LLc on streets... do you think na okey lang yun?
    Maraming salamat muli
    Sir BMGregorio, 4H lang talaga ang magagamit pag sa city, yung sa amin, gusto ko rin i-test yung 4HLc at 4LLc, pero hindi sya pwede sa paved, kailangan talaga yung off road condition, the best gamitin yung 4H, during rainy situation or minsan kailangan mag-overtake, mabilis ang response time....
    Sir Bengbeng,
    Sa akin naman po, maintain full tank method po ang ginagawa ko, para iwas sa moisture sa fuel tank at iwas corrosion na rin...
    pag nagamit, pag medyo nabawas na sa 3/4 Full, karga agad.
    Mar 2013
    #1285
    palagay ko, yung baterya ay mahina na.
    kumpara sa pag-papa-start ng makina, mallit lang ang kuryenteng kailangan ng dashboard and lights.
    subukan mong pakargahan ang baterya, o mag-jumper cable piggy-back (jump start).
    hindi tatagal ang karga ng baterya kapag idling lang... yung kinarga ng baterya sa idling, ay kulangpa sa kuryenteng ginamit sa pag-start..
    dapat ay ilabas sa lansangan at hayaang tumakbo nang mas mabilis sa idling rpm..
    er... gaano na ba katagal na hindi lumalabas ng garahe si monty?
    good luck.
    ^mga 5 months old palang yung monty at 3 months na sir na hindi nagagamit puro lang warm up. sige sir pa charge ko muna. salamat sa tulong.
    Mar 2013
    #1286
    5 months old palang yung monty sir kaso 3 months na hindi nakakatakbo puro lang warm up once a week nga lang. cge sir pa charge ko baka nga na drained talaga. Salamat po sir.
    Jul 2010
    #1287
    Quote Originally Posted by playplugg View Post
    Pards, di rin magandang nagsstock ng diesel ng matagal. Pagkakaalam ko may expiry yan within weeks... Based sa iba mong post, bihira mo gamitin ang MS mo, it might do more harm than good. I suggest gamitin mo ang diesel til less than 1/4 ng gauge prior top up.
    Re: Petron Diesel, di rin ako nagamit nun. I use Sea Oil (both MS at sedan). May nakasabay na ko sa casa 6k kms palang sya ng CEL na. Tsaka nirecommend din sa kin nung dealership na wag gagamit ng Petron, as kadalasan ng nagCEL sa kanila, Petron ang gamit.
    #1288
    Quote Originally Posted by boytsiks View Post
    Sir boytsiks,
    Thanks po sa good info, about the concerns regarding sa petron diesel, and the procedures kung kailan ulit mag-top up ng diesel,
    Since March po, nasa 125KMS pa lang yung takbo ng monty namin, once a week ko lang po napapa-andar at napapatakbo, para hindi ma-discharged yung battery and ma-lubricate yung mga bearings/gear oils,
    and also po, May pa ang huling karga ko sa diesel, and till now, nasa Full pa rin yung gauge,
    kaya lang naman po ako nag-full tank lagi, para maiwasan yung moisture sa fuel tank pag hindi ginagamit.
    yun sa uncle ko naman po, sa province nila sa leyte, petron dieselmax ang gamit nya, same method din, at ni minsan hindi sya nagkaroon ng CEL, yun lang, lagi ginagamit, from tacloban to ormoc, vice-versa.
    If time permits talaga, gagamitin ko na rin yung monty para ma-break in ng husto para ma-consume na rin yung diesel sa fuel tank,
    (meron po talaga expiry at shelf-life ang mga fuels/lubricant, depende kung paano ang means of storage)
    since yung old car namin, gamit pa rin ng parents ko at sa akin pinagka-tiwala yung monty, pero i decide na hindi na lang gamitin, kasi busy rin ako right now for my schooling...
    pag natapos na siguro yung schooling at training, saka ako mag-celebrate kasama ang montero.. hehehe...
    Apr 2013
    #1289
    Sir Bengbeng,
    Good for you bro, iba kasi contaminated na diesel ng petron, naalala ko pa yung FM days ko, gf ko pa si misis, nag pa full tank ako sa petron sa kanila sa bulacan, pag dating ko ng nlex cel ako. Sa awa ng diyos nakauwi pa ko sa bahay, pinapunta ko mekaniko namin sa bahay duda niya dirty fuel filter, pag bleed niya, krudo na may halong tubig lumabas. Tpos we decided nlng na i drain yung diesel sa tank para sur. almost 1/4 ng tank puro tubig, After that incident hndi nako nag pakarga sa petron. diretso nko sa seaoil, ayaw ko lang sa seaoil hirap humatak. hehehehe!
    Feb 2007
    #1290
    ^sir beng, yan na ba yung with STP additive nila yung mahirap humatak? Tried Shell FS/Petron DM/Seaoil pero parang pareho lang e. Still a Seaoil user pag nasa Manila.
    Wala kasi sa province pag nauwi, except the B3.
    Sent from my Nokia5110i-VgT using Tsikot Forums
2014 mitsubishi montero
