Page 131 of 138 FirstFirst ... 3181121127128129130131132133134135 ... LastLast
Results 2,601 to 2,620 of 5877
    Dec 2012
    Quote Originally Posted by myas110 View Post
    hi...any dealers who give big discounts and generous freebies for the Mirage? thanks
    Hello sir share ko lng sakin nkuha ko last 7th oct.
    Srp nya 583000 pero may discount daw na 60k
    Pero sa invoice e wla nmn tcp is 583k padin
    Binawas lng sa dp kya low,
    Dp all in 57,800
    3yrs e 16946
    Kpg 4yrs 13576
    Free standard chattel, lto, insurance, tint na lumina siguro not 3m,
    Ung seat cover hindi din mgamit at puting tela lng.
    Binabargain k sna at least rain gutter at back sensor kaso
    Nagsad story ahente ni ibabawas daw sa kanya etc.
    E kinumpute ko nmn sa 3yrs patok narin priority pa magkano lng interest sa east westbk nila ipinasok,
    In case punta kayo sa otis paco
    Jun 2012
    ^sa text ba kayo naguusap ng agent? May mga agent na ayaw ilista sa text ang freebies. Pero sa formal quotation dapat andun ang freebies. Lahat ng napagusapan nyo
    Aug 2015
    Quote Originally Posted by dct View Post
    naka-list naman po sir ung mga normal freebies, but we're haggling po kc sana na makakuha pa ng added. and sabi po ng iba ko na din nabasa dito sa tsikot depende daw po sa dealer/SA ung mga dagdag na nakukuha
    Jun 2012
    Quote Originally Posted by bossLele View Post
    Kung ayaw nya ilista wala kang proof pag di nya binigay. So wag maniwala. Dapat ilista nya
    Mar 2015
    Kahit po d nilista ok lang sir basta nagkasundo kayo kung ano yun freebies. May catch yan to protect your interest. Basta before they make you sign that document of acceptance make sure lahat usapan nyo nakalagay na sa kotse nyo. If you don't sign the acceptance wala sila magagawa. You can reject the unit until they comply with your deal. [emoji4]
    Dec 2009
    Mga tol ano recommend tire pressure nyo sa mirage?
    Jan 2012
    nasa may driver's side nakasulat yung recommended tire pressure
    Dec 2009
    Quote Originally Posted by kimot View Post
    Parang natataasan kasi ako. According sa manual 1-3 pax 36 front 33 rear. Pag 4-5 ang sakay 38 front & rear. Normal lang ba un sa 165/65 r14?
    Jan 2012
    sundin mo sir kung ano yung nakaindicate sa manual/driver's side. afaik nakasulat rin dyan yung specs ng gulong.
    mahirap kasi kung di mo susundin, you're sacrificing the thread life and your safety.
    the recommended tire pressures are indicated in a sticker pasted to the driver's door pillar, as well as indicated in the manual.
    yung wigo namin, mataas din yung recommended pressure. but we have been doing it for a year now.. ok naman.
    Dec 2009
    Ahh. Sa Adventure ko kasi halos lahat ng nakausap ko na advie owner hindi nila sinusunod yung recommended na 26 front 36 rear. Karamihan 35 front & rear or 30 front 33 rear.
    Completely agree. Theyve tested these for many years during the development. For best traction and fc and overall safety id follow the recommended tire pressure. Even tire manufacturers recommend 35psi for this tire size for mirage specific applications.
    Apr 2014
    Masyado matagtag yung 35psi sa akin. I normally hover between 32 to 33 psi lang.
    Dec 2009
    Tire pressure is like inflation, it lessen in value as time pass by
    I see variation in tire pressure at around 2 psi (going up) thru my tpms when you use it in hot weather.
    Dec 2009
    Nelany, thats a fleeting moment, it will never last long..pressure will go up as temperature surge
    Bottomline is tires deflate as a function of time from the moment you inflate it up to the time you reflate it
    Since 2 psi lang ang increase ng pressure so me idea na kung anong max pressure sa highway. Better install a TPMS if you want to monitor yung tire pressure mo.
    Dec 2009
    TPMS is not practical for every car owners
    The point you raise about a slight increase in pressure on a warm temperature or as the tire roll and get warm is a good point to remember
    To prevent bursting the tire while on the run, a user should provide allowance if one intends to pump air at a maximum level. For example if the max tire pressure is 44 then 42 is about right not to over inflate the tire to provide allowance due to increase in temp
    Dec 2009
    U mean sir ok lang yung 38 pag max is 44? May nababasa kasi ako na sometimes pag masyado mabilis takbo nasa 5 to 10 psi yung nadadagdag.
    Dec 2009
    Quote Originally Posted by radz15 View Post
    tire pressure decays in time except when the tire gets hot due to fraying while rolling on the road or due to convection when tire sits on a paved road during the hottest period of the day (noon time)
    Nelany had observed that its just 2psi with TPMS, a slight increase compared to 5-10psi. Again this is temporary as the ambient temperature of the wheel together with the surroundings goes down the pressure will also go down
    Just take note of the effect of heat with tire pressure and take due caution by providing allowance in reaching the max
2013 Mitsubishi Mirage
