Results 5,721 to 5,730 of 5870
September 8th, 2015 06:09 PM #5721
Yun po kasing lifespan sa manual po namin since 98 model po sya until now wala pong naging sira kahit 1beses yun coventional na a/t po namin 97 model nasira after 10years. Sa Cvt po kasi may technique sa pag gamit. Huwag nyo pong biglang babaon kung galing sa full stop(jack rabbit) hayaan nyo po muna gumulong nang konti. Ganun din po sa paglipat nang gears dapat kumapit muna bago kayo umandar. Bigyan nyo time mag engage yun transmission. Sa traffic po lagi nyo na lang lagay sa N wag nyo pabayaan nakababad sa D at naka preno lang kayo.
Kung matutunan nyo tamang pag gamit sa Cvt at regular change Atf (oil) nya matagal din yan kahit 15yrs or more. Estimate ko lang po or 300,000kms?
- Aug 2015
- 8
September 8th, 2015 06:22 PM #5722naka-list naman po sir ung mga normal freebies, but we're haggling po kc sana na makakuha pa ng added. and sabi po ng iba ko na din nabasa dito sa tsikot depende daw po sa dealer/SA ung mga dagdag na nakukuha
- Jun 2012
- 4,448
September 8th, 2015 06:27 PM #5723
September 8th, 2015 06:31 PM #5724
Kahit po d nilista ok lang sir basta nagkasundo kayo kung ano yun freebies. May catch yan to protect your interest. Basta before they make you sign that document of acceptance make sure lahat usapan nyo nakalagay na sa kotse nyo. If you don't sign the acceptance wala sila magagawa. You can reject the unit until they comply with your deal. [emoji4]
October 3rd, 2015 01:34 AM #5726
nasa may driver's side nakasulat yung recommended tire pressure
October 3rd, 2015 01:44 AM #5727
October 3rd, 2015 02:51 AM #5728
sundin mo sir kung ano yung nakaindicate sa manual/driver's side. afaik nakasulat rin dyan yung specs ng gulong.
mahirap kasi kung di mo susundin, you're sacrificing the thread life and your safety.
October 3rd, 2015 03:02 AM #5729
- 52,731
October 3rd, 2015 07:56 AM #5730- - - - - - - - - - - - - - - - - - - - - -
the recommended tire pressures are indicated in a sticker pasted to the driver's door pillar, as well as indicated in the manual.
yung wigo namin, mataas din yung recommended pressure. but we have been doing it for a year now.. ok naman.Last edited by dr. d; October 3rd, 2015 at 07:59 AM.
high idle RPM at engine start
