Results 5,721 to 5,730 of 5877
- Aug 2012
- 2,767
October 3rd, 2015 01:44 PM #5721"Inflate your front tires to 36 psi in the morning" >> This is the cold tire air pressure.
"and then after you use the vehicle, measure the tire air pressure again." >> This is the hot tire air pressure.
The purpose here is to know the maximum air pressure inside the tire during normal use.. since according to radz15, tire sidewall indicated 44 psi as maximum for his tires.
- 54,234
October 3rd, 2015 01:48 PM #5722
October 3rd, 2015 02:57 PM #5723
Tire pressure is like inflation, it lessen in value as time pass by
October 3rd, 2015 03:12 PM #5724
I see variation in tire pressure at around 2 psi (going up) thru my tpms when you use it in hot weather.
October 3rd, 2015 03:35 PM #5725
October 3rd, 2015 03:42 PM #5726
Nelany, thats a fleeting moment, it will never last long..pressure will go up as temperature surge
Bottomline is tires deflate as a function of time from the moment you inflate it up to the time you reflate itLast edited by kisshmet; October 3rd, 2015 at 03:45 PM.
October 3rd, 2015 08:51 PM #5727
Since 2 psi lang ang increase ng pressure so me idea na kung anong max pressure sa highway. Better install a TPMS if you want to monitor yung tire pressure mo.
October 4th, 2015 10:03 AM #5728
TPMS is not practical for every car owners
The point you raise about a slight increase in pressure on a warm temperature or as the tire roll and get warm is a good point to remember
To prevent bursting the tire while on the run, a user should provide allowance if one intends to pump air at a maximum level. For example if the max tire pressure is 44 then 42 is about right not to over inflate the tire to provide allowance due to increase in temp
October 4th, 2015 10:16 AM #5729
October 4th, 2015 10:37 AM #5730
Yup TPMS is not practical for all, but if the owner is keen on the tire pressure he may install one. Meron owner na metikuloso sa ganyan so installing one will be the answer.
I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
Mineral , semi synthetic or fully synthetic?
