Results 4,261 to 4,270 of 5870
- Jan 2013
- 39
January 23rd, 2013 09:53 PM #4261
- Oct 2012
- 144
January 23rd, 2013 10:09 PM #4262Hi mga ka mirage....for those na nakapagpaPMS na for 1K....same p rin po ba ung fuel consumption nyo or much better kung nag improve...merong mga reports na nagdegrade ang fuel consumption nya...for your confirmation
thanks
- Oct 2012
- 73
January 24th, 2013 08:50 AM #4263
- Oct 2012
- 16
January 24th, 2013 09:00 AM #4264
- Nov 2012
- 50
January 24th, 2013 03:14 PM #4265Question po ulit regarding Manual trans..
Nakakasira ba ng clutch if I will use half clutch and half gas esp. When uphill or inclined area(traffic or slowly moving)
Thanks
January 24th, 2013 03:29 PM #4266
- Nov 2012
- 50
January 24th, 2013 03:41 PM #4267Ahh opo ramdam naman. Newbie pa kasi hehe.
Pero sir question ulit.
Di naman nakakasira or upod ng clutch lining(di ko sure kung yun tawag) kapag half clutch and half gas when not moving sa matarik na daan, like sa traffic ganyan.. Kasi usually when you did that your car won't move parang nakabrake. Ok ba siya? Or affected si clutch na pwede masira pag ganun kaya mas mainam pagbrake nalang gagamitin tapos change to accelerator when "go or car starts moving in front of you..
Thanks, sobrang newbie palang kasi hehe natatakot maatrasan ang nasa likod kaya I use this half clutch and half gas. May konting atras kasi pag brake then change to gas. Yung iba kasi grabe makabuntot e.
- Jan 2013
- 4
January 24th, 2013 03:58 PM #4268Hi. ask ko lang if yun bang LCD monitor sa GLS ay GPS na yun or display lang sya para sa mga sounds, etc,. tnxx
- Oct 2012
- 31
January 24th, 2013 04:33 PM #4269GPS enabled and loaded with map na rin po yung hu ng gls..
Sent from my GT-P6200 using Tapatalk 2
- Jan 2010
- 367
January 24th, 2013 05:35 PM #4270sir, wag nyo pong gawing habit yung tinitimpla yung clutch and gas accelerator to prevent it from moving backward tulad nung kalimitang ginagawa ng ibang mga jeepney drivers when approaching sa mga tulay and nakahinto dahil sa trafic, parang nililiha nyo yung clutch disc nyo, mapapa-aga ang pagbaba ng transmission nyo. Kalimitan ginagawa ng mga naka manual transmission ay naka handbrake lang while in neutral kung matrafic when approaching slope. To start moving the car, apak lang sa clutch, shift to first gear then timing lang sa pag apak ng accelerator and pag release ng handbrake and ng clutch....
high idle RPM at engine start
