Page 427 of 585 FirstFirst ... 327377417423424425426427428429430431437477527 ... LastLast
Results 4,261 to 4,270 of 5843
    Jan 2013
    #4261
    Quote Originally Posted by deathwish27 View Post
    guys may official forum na ang mirage peeps :D
    www.miragepilipinas.com
    hehe nagregister naman agad ako haha tnx!
    #4262
    Hi mga ka mirage....for those na nakapagpaPMS na for 1K....same p rin po ba ung fuel consumption nyo or much better kung nag improve...merong mga reports na nagdegrade ang fuel consumption nya...for your confirmation
    thanks
    #4263
    Quote Originally Posted by mitsumirage1979 View Post
    thanks
    more or less same pa rin sa akin...
    #4264
    thanks
    hi GLS CVT here... sa case namin ramdam na ramdam ang improvement after ng 1k pms kaya medyo arangkada kaya bumaba to ~12km/L. pero now na chill driving ulit back to ~17 km/L (MID)
    Nov 2012
    #4265
    Question po ulit regarding Manual trans..
    Nakakasira ba ng clutch if I will use half clutch and half gas esp. When uphill or inclined area(traffic or slowly moving)
    Thanks
  6. #4266
    Quote Originally Posted by nakz View Post
    Thanks
    Nakakaupod. Pag kapit na and mukhang di namamatayan, slowly release. Pag uphill, ramdam mo naman pag fully egaged na yung clutch. The first gear's ratio is enough to pull it up maski matarik pa. Magiging prone sa slide if you remain halfway sa clutch.
    Nov 2012
    #4267
    Quote Originally Posted by kompressor View Post
    Ahh opo ramdam naman. Newbie pa kasi hehe.
    Pero sir question ulit.
    Di naman nakakasira or upod ng clutch lining(di ko sure kung yun tawag) kapag half clutch and half gas when not moving sa matarik na daan, like sa traffic ganyan.. Kasi usually when you did that your car won't move parang nakabrake. Ok ba siya? Or affected si clutch na pwede masira pag ganun kaya mas mainam pagbrake nalang gagamitin tapos change to accelerator when "go or car starts moving in front of you..
    Thanks, sobrang newbie palang kasi hehe natatakot maatrasan ang nasa likod kaya I use this half clutch and half gas. May konting atras kasi pag brake then change to gas. Yung iba kasi grabe makabuntot e.
    Jan 2013
    #4268
    Hi. ask ko lang if yun bang LCD monitor sa GLS ay GPS na yun or display lang sya para sa mga sounds, etc,. tnxx
    #4269
    GPS enabled and loaded with map na rin po yung hu ng gls..
    Sent from my GT-P6200 using Tapatalk 2
    Jan 2010
    #4270
    sir, wag nyo pong gawing habit yung tinitimpla yung clutch and gas accelerator to prevent it from moving backward tulad nung kalimitang ginagawa ng ibang mga jeepney drivers when approaching sa mga tulay and nakahinto dahil sa trafic, parang nililiha nyo yung clutch disc nyo, mapapa-aga ang pagbaba ng transmission nyo. Kalimitan ginagawa ng mga naka manual transmission ay naka handbrake lang while in neutral kung matrafic when approaching slope. To start moving the car, apak lang sa clutch, shift to first gear then timing lang sa pag apak ng accelerator and pag release ng handbrake and ng clutch....
2013 Mitsubishi Mirage
