Results 41 to 45 of 45
Tsikot Member Rank 1
- Jul 2009
- 4,090
April 7th, 2014 01:06 PM #42
Sir ondoy2008 saan branch ng el dorado mo pinagawa? Ganun din problema ng advie ko. Thanks.
- Apr 2007
- 92
June 7th, 2014 06:49 PM #43Regarding TOK Sound. Steering coupling nga yan. Pag remedyo, linalagyan lang nila ng plastic. Para hindi tumunog.
But the best is to have it replaced. If your adventure is still under the 3year warranty, then replacing the steering coupling under warranty is free. As in Free, you just have to drive in and ask the service advisor to have your unit check and replace if needed.
But just in case the Adventure is not anymore under warranty, then you might as well replace the steering coupling.
I got mine replaced by a friend in Manila. However, by appointment lang sya. The Mechanic is very well experienced. Look for Mang Endoy. I have mine replaced with a new steering coupling, damage is 7k inclusive of labor.
Will check with him if its ok to post his number here.
June 8th, 2014 09:36 AM #44
Sir ice15 nakapagpalit na ba kayo ng third seats para maging 7 seater? If not yet I know the supplier of the OEM seats that supply them to Mitsu... Pero you'll need to replace quarter panel trims kasi un 9 seaters have 5 holes on the trim panels at pag nagpalit kayo 7 seater na meron 3 holes lang sa panel.
June 8th, 2014 09:39 AM #45
high idle RPM at engine start
