Page 25 of 33 FirstFirst ... 15212223242526272829 ... LastLast
Results 481 to 500 of 642
    Aug 2013
    #481
    Quote Originally Posted by cardict View Post
    Bro better siguro ulit in mo process,start from scratch,baka may na limutan kang procedure,no harm in trying,makukuha mo yan
    Sir di kaya dun sa file may problema? tama naman kasi sa pag extract, ilang beses ko nadin natry...
    Feb 2007
    #482
    Sir pepa if dito nyo rin na download yung papago files then it should work..
    What i did was i printed out the instruction on how to do the installation, na naka post din dito sa forum. Balikan nyo po every step and make sure they are carefully followed.
    Wala at di po masisira yung unit nyo just installing the GPS map kaya as mentioned by cardict, try lang ng try.
    I suggest you go backs to the thread and read more kasi andyan lahat yung answers sa maaari nyong maging katanungan pa..
    Kaya nyo po yan.. ;)
    Aug 2013
    #483
    Go to destination>type your address>simulation>go>add to favorite >home,try it,hth
    Sir cardict, kelangan ba tapusin itong simulation?... ang nakalagay parang 20 hours pa bago makarating sa amin itong simulation. hehehehe meron bang ibang paraan para gumana ng maayos?
    Feb 2007
    #484
    Tagal nga yan sir haha!
    Pagbukas nyo po ng navi may nagsasalita po ba na "searching for satellite"?
    Aug 2013
    #485
    Yup. Meron po sir...
    Apr 2013
    #486
    Quote Originally Posted by warshock729 View Post
    Better yet skip mo na lang simuation,after typing your address,click ok,it will take only a few seconds for the sattelite to fully find it,once you see it loaded 100% add it to favorite then make it your home
    Aug 2013
    #487
    Natapos ko na po nalagay sa favorite sir cardict. Then naayos ko na din ang sa office. ang problema, pgisimulation mo xa, pareho pa rin, dun pa rin xa ngsisimula sa my sucat. hope you can help me on this... baka my nakalimutan lng ako o kaya my kulang pa na files....
    Apr 2013
    #488
    Then try mo click destination yun talagang Lugar na gusto mo puntahan,makikita mo below the screen ,go at function,before mo I click yun go,click mo function then current position ,lastly click go.do it pag nasa labas ka at paalisin ka na
    Aug 2013
    #489
    Ok po sir cardict. Will try your suggestion... Thanks... will update you pgnatry ko na...
    Aug 2013
    #490
    Siguro nga need ko talaga idouble check kung tama ba talaga ginawa ko, post ko agad result kung napagana ko na.. many thanks sa inyo sir prince at sir cardict!
    Feb 2007
    #491
    Sir Pepa, you can give me your email address para masend ko sa inyo yung steps sa installation na nai-print ko....
    Aug 2013
    #492
    Sir I tried it again today still not working parin.. parang hindi binabasa yung files sa sd, nag try ako mag lagay ng blank sd card eto lang din yung nag appear
    eto yung details dun sa system
    baka hindi supported yung papago?
    Feb 2007
    #493
    Curious lang sir, di kaya nakalock yung sd card? ;)
    Try nyo new sd card at doon nyo extract yung files..
    Aug 2013
    #494
    I'm losing hope na mapagana pa yung gps sir. I tried all the possible solutions but still its not working.. haizzz 3 different sd cards na ginamit ko all is 4gb yung capacity, di naman din naka lock yung mga sd.. ... mukang need pa yata bilin yung sd ng advie.. mahal pa naman..
    eto nagpapahirap sakin,,, yan lang talaga lumilitaw ginaya ko na nga yung destination folder nilagayan ko ng "Navigation" folder yung sd then dun ko inextract yung mismong laman nun rar.. kapag naman nag browse ako wala namang laman.. hindi kaya naka lock yung HU?
    Feb 2007
    #495
    Not sure how but did you try i reset yung HU sir? Sa Montero kasi meron kasi small hole to reset, di ko lang macheck ngayon sa advie kasi nasa province yung unit ;)..
    Nga pala sir....
    Sent from my N5110 using Tapatalk Pro
    Aug 2013
    #496
    Nga pala sir....
    Ganito lang sya.. naitry ko sya ireset at idefault lahat ganun parin.. di ko lang alam yung sa sinasabi mo na reset button kung san sya nandon..
    Feb 2007
    #497
    Both sa root folder at nakalagay sa folder(i.e. Navigation) nakalagay yung files - ganyan lang lumalabas sir? - blank file list?
    Eto yung files na ilinagay ko sa root folder ng SD card sir.
    Aug 2013
    #498
    No luck talaga sir di talaga binabasa yung files T_T na reset ko na ganun parin..
    Feb 2007
    #499
    If may kakilala kayo sir na meron legit na NAVI SD Card at pwede ninyo mahiram para matry nyo rin po, baka yung HU ang may problema..
    Just thinking...
    Sent from my Nokia5110 using Tapatalk Pro
    Aug 2013
    #500
    Just thinking...
    Oo nga yan na naisip ko,,, baka may problema nga yung HU btw thanks for the help hehe..
2012 Mitsubishi Adventure?
