Page 179 of 251 FirstFirst ... 79129169175176177178179180181182183189229 ... LastLast
Results 3,561 to 3,580 of 5006
    Sep 2011
    #3561
    Quote Originally Posted by migs0624 View Post
    Hi Sir, I intend to remove the egr, not clean it. Is it possible?
    Baka mag check engine light yan sir, if there is a way to trick or reprogram the computer NA may EGR system Ka kahit wala pwede malamang ;). I based my assumption dun sa mga nagsasabi NA naglight up CEL nila and based sa CASA diagnostics barado o sira EGR valve nila
    Nov 2011
    #3562
    ^^... Master zix among the three wheels pinaka bagay po sa inyo #3.magkano po kaya si boy tawilis pag magsawa kayo?hehe
    #3563
    Quote Originally Posted by silver V View Post
    pm kita agad if ever makakuha ko sir ng kapalit ni tawilis
    Nov 2011
    #3564
    ^salamat po master zix
    Feb 2007
    #3565
    Sorry sa mga nag reserve ng sd cable, reverse cam at keyfobs pag naunahan kayo.. First pay first serve uli tayo..
    Jul 2012
    #3566
    hello guys meron ako 2009 monty gls 4x4..so yung seats nya sa harap ay manual pa po...nakabili ako ng isang set na seats pang gtv bnew nka plastic pa so power seats na po yung pang driver side ang tanung ko po may abang ba na wire sa gls or mag wiwiring nalang ng panibago coz alam ko positive ska negative nalang po yun kse yung switch nsa upuan na...tnxs po
    Jul 2012
    #3567
    ska may kukuhanin din sana ako na gps na 2din oem ng gtv montero isang set ang prob kaya d ko kinuha muna kse walang socket yung sa pinaka stereo..ang sbe sa akin kaya daw yun nila winterpine kahit walang socket...tanung ko guys fit kaya yung stock 2din multifunction display sa gls montero ko.gagana po kaya lahat ng features like altimeter,compas or whatsoever...flooded nga po pala unit ko last ondoy pero na correct na po lahat sa casa..
    Sep 2010
    #3568
    Hello fellow tsikoteers... Has anyone upgraded to rancho shocks? Noticeable ba sirs nag improvement? Thank you in advance sa reply....
    #3569
    just finished my auto dimming rear view mirror. sarap ng mitsu rin pinanggalingan, bolt-on lang, wiring naman lapit lang sa map lamps, mat ready + 12v agad
    Apr 2012
    #3570
    Quote Originally Posted by akosijepoii View Post
    I have the same issue. Nakakuha din ako ng gtv seats. Walang abang na wire for the seats. Mine is non vgt unit. Nakuha mo ba yung male plug para sa power seats?
    Wires are colored red/white and black.
    Sa mga naka gtv, may i ask san naka plug yung red/white sa dash?
    Sent from my iPad using Tapatalk HD
    #3571
    Quote Originally Posted by jns888 View Post
    there is no trick in making your seats work. just have the red/white go to the positive (+) terminal of the battery, then grounding (-) for the black wire. just put a fuse( it says there 40A).
    Jul 2012
    #3572
    Quote Originally Posted by zix888 View Post
    actually nakuha ko yung set ng seats wala yung male socket gnawa ko bumili ako ng male and female socket since dalawa lang naman wire nag splice nalang ako then kumuha ako ng direct live wire nilagyan ko nalang ng fuse holder and naglagay ako ng relay ayun ok na sya..isa pang case d ko alam kung kukunin ko sa friend ko yung gps and head unit galing sa gtv..ang problem ko yung sa monitor may socket pero yung head unit mismo wala..makakabili kaya ako sa winterpine ng socket lang ng head unit
    Apr 2012
    #3573
    Thanks for the illustration. Does this mean na wala talafang plug/wire sa dashboard/fuse box para mapagana yubg seats? Also, napansin ko lang na meron option for height adjustment? Parang 2 buttons lang yung napansin ko sa driver seat. Forward/backward and recline
    Sent from my GT-N7000 using Tapatalk 2
    #3574
    Has anyone experienced turbo failure on their monty because of not cooling down their turbos after a long drive or not having a turbo timer?
    May 2009
    #3575
    sir akosijepoii, can i ask if saan kayo naka kuha ng OEM GTV seats?
    May 2009
    #3576
    sir jns888, may i ask if may contact no. kayo sa autoline? taga cebu kasi ako. or if you have the part no. of this panel kit? thanks
    Jul 2012
    #3577
    Sa pampangga sir heheh dme naten pyesa dun even mga switch at ibang small parts kaya wala tayo problem kung magka prob sa monty naten may mabibilhan ng surplus hehehe may nakuha ako condenser 2k gud as bnew may tupi tupi na kse fins nung akin kaya binili kuna..pero dapat may contact or may kakilala ka sa loob ng compound nila
    Jul 2012
    #3578
    Seats ko ng gtv nabili ko 15k isang set may plastic pa nga gps monitor ko for gtv kasama head unit 13k yun nga lang walang kasamang socket yung head unit kaya sana meron kila winterpine at pag bentahan ako...
    Feb 2012
    #3579
    Good pm, am new here. I would like ask for your help where to buy monty's accessories such as projector headlights with angel eyes, projector fog lamps with angel eyes, smoke led tail lights, body kits, and others accessories you know of for monty. If somebody here knows of such suppliers or you are a supplier of such accessories please let me know. We are in a group to buy such accessories here. By the way,am from Davao City and I own a montero sports gls-v 4x2. Hope you could help us guys find a supply with a reasonable price, of course.hehe.. TIA
    May 2009
    #3580
    *akosijepoii wow! 1 set seats? u mean driver passenger etc. for 15k?? mura nga ng head unit sir. may kakilala kaba doon? cebu based kasi ako e. hehe
2011 Mitsubishi Montero Sport [continued]
