Results 4,031 to 4,040 of 5006
Tsikot Member Rank 1
- Jul 2009
- 4,090
July 20th, 2013 02:32 PM #4032
- Jul 2009
- 4,090
- Nov 2011
- 427
July 20th, 2013 08:42 PM #4034Dati nasa 1800 lang din.. 105k kms na natakbo ngayon. di ko pa napapalinis yung egr. Yun kaya ang problema? Ang hina na kasi ng hatak e.
Magkano po ba yun pagawa sa casa? and may check engine light pala, pabalik balik lang. hindi pa napapacheck kasi di na ako gumagamit nito e..
- Aug 2003
- 317
July 22nd, 2013 08:20 AM #4035clairenceh, since high mileage ka na, yung hina ng hatak may be due to a number of factors. Check your air filter and fuel filter if they have been replaced recently. The EGR may be dirty and so is the intake manifold. Your intercooler may already be full of oil especially if you dont have an OCC, time to cleanse it. Check if you had the valve tappets adjusted already. Clean the MAF sensor if needed. Do an SIQL sa casa.
Since out of warranty na, after doing the following procedures, probably you may want to blank your EGR.
- Apr 2013
- 68
July 22nd, 2013 10:02 AM #4036
- Aug 2010
- 24
July 24th, 2013 12:42 AM #4037Sir zix, done cleaning may intake manifold yesterday.. 3days work din since its mY first time magbaklas ng manifold.. my egr blanked and tested na din, ayos na ayos.. lakas na ulit ung hatak.. napangiti talaga ako sa performance nya.. sana lng d umilaw cel for blanking may egr.. test ko ulit knina driving for only 40kph (kasi nagoopen daw yta ung egr valve ng less than 2500rpm), 30kms and idle for more than an hour so far d pa umilaw.. i also adjusted my waste gate actuator kya ang aga magspool ng turbo.. now, napapaisip tuloy ako, bkit pag sa casa laging advise na linisan ang egr kung d rin lang pati intake manifold.. what for kung ung egr pipe lang? D mabuti pa ngang barado na un para parang nablank na din lang egr,,
- Aug 2010
- 24
July 24th, 2013 12:44 AM #4038Sorry kung d masyado maintindihan post ko.. not really good in car forums.. now, pano po lilinisan ung intercooler? Since langis po yta dumadaan dun? Any advice please,, TIA..
- Aug 2010
- 24
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
