sir, is it possible to remove a medium to deep scratches on the plastic rear bumper?
JVC din Bro kaso audio lang cya, hindi kasi makita nang installer yong steering wheel control interface sa unit ko, kong mayroon o wala, so pag wala bibili nalang ako. Gumana naman yong steering control sa taga Montero Sport na ginaya ko. kaso sa winterpine kasi nya pina install yong HU. Di bali I can solve this prob. in due time.
Sirs, I'm planning to have my 1,000Km oil change this friday. I'm considering Motul Multipower (15W-50) technosynthese (semi-synthetic) oil. Eto lang kase available sa distributor (http://elmerfrancisco.com/motulmultipower). Close din kase sa recommended oil specs sa manual. Any comments on the oil?
mga sir tanong lang po, sa mga nag palit ng wheels/ tire, newbie question. pag stock form pa, yung isang ikot ng gulong accurate pa yung odometer since stock, kinorrect nyo pa po ba yan nung nag palit kayo wheels/ tire? pano na magiging computation? Thanks.
pwede naman yan sir....kaso its below the recommended grade of 15w40 for synthetic oils...better siguro sir if maghanap ka ng the same or higher grade like 10w40 or 5w40....
hehe...natanong ko din yan sir dati....kaso masyado naman ng minor para pag isipan pa hahaha!....basta umaandar yung odometer at natutulungan ako sa distance calculation at PMS ok na yun....and BTW nothing was done whatsoever...
[/quote]
Thanks you sir!
[quote=locoroco777;1557052]pwede naman yan sir....kaso its below the recommended grade of 15w40 for synthetic oils...better siguro sir if maghanap ka ng the same or higher grade like 10w40 or 5w40....
repsol elite na langis may nakita ako sa may alabang town center sa mga shop sa gilid. ganito ata yung ginamit sa dakar - poster nila sa casa.
Description
High quality synthetic based lubricant specifically designed to satisfy the needs of the most modern petrol and diesel engines. The presence of synthetic components gives the product high thermal stability and high performance, which permits longer drain periods.
Qualities
· Easy starting and lubrication at any temperature.
· Reduces fuel consumption.
· High resistance to chemical degradation.
· Excellent thermal stability.
· Less friction than mineral oils.
· Long life oil
· Its low viscosity contributes to the optimum functioning of hydraulic valves.
http://www.pms.net.au/03_repsol_PMSREMU_40.htm
Ok. Thanks. Just bought ZIC SD 5000 multi-grade for Php 170/liter. http://www.skzic.com/eng/user/produc...duct_02_04.asp
mga sir, ask ko lang. im about to send my strada for its first 1000km check-up sa citimotors alabang. the problem is sobrang loaded na sila until next week. obligado b dapat sa kanila ko lang ipagawa o pwede din sa ibang casa na malapit sa amin like amcar sta. rosa? iniisip ko kc baka singilin ako ng labor pag sa ibang ko dinala. salamat po.
Mga sir san po alam nyo na meron available na rear sensor... pag umaatras... yung wala po monitor ung tutunog lang pag lapit na bumangga.. hirap umatras ang laki ng likod.. (GSM Sportslid)
