Page 36 of 75 FirstFirst ... 2632333435363738394046 ... LastLast
Results 701 to 720 of 1485
    Nov 2006
    #701
    guys... may immobilizer ba ang gls sports natin?
    Feb 2010
    #702
    Quote Originally Posted by krinkx View Post
    i think wala yata. but may aftermarket immobilizer ba that we can install on our units?
    Mar 2004
    #703
    2010 GLS Sport models have immobilizers.
    Nov 2006
    #704
    ah ok, thanks, i have 1 month old gls sport, does that mean that i cannot have the key duplicated by mr. quickie or other key duplicators?
    Aug 2010
    #705
    Mga sir, I need you opinions po ulit. white glx po kukunin ko next month. Would you prefer fender flares only (body color) or fender flares with body claddings (body color din pareho)? Maraming salamat po sa tulong.
    Jun 2009
    #706
    Hi'
    I was driving yesterday coming from the Fort & I tried to overtake one slow moving car when biglang kinapos at bumagal my strada (3.2 A/T)I presumed this is the fuel pump problem mentioned in the forum, kasi prior to this I had an experience na nag ilaw ang warning lights sa dashboard ko, nagkataon na malapit ako sa mits shop, they check it & cautioned me in case na umulit uli ibalik ko sa kanila.
    I had finished my 20k check up , is it 30K next ?, bago mag lapse yung warranty I will urge them to change yung SCV ba ? or fuel pump which ever.
    RTS
    Dec 2007
    #707
    ^^ either barado na EGR mo or kailangan palitan ang SCV... covered naman ng warranty yan
    Aug 2010
    #708
    Mga sir, I need you opinions po ulit. white glx po kukunin ko next month . Would you prefer fender flares only (body color) or fender flares with body claddings (body color din pareho)? Maraming salamat po sa tulong.
    Sep 2004
    #709
    Quote Originally Posted by RTS View Post
    Hi'
    RTS
    sir, can you tell us what Mitsu said when you brought it in? what did they do? please tell us more on what transpired when they checked your units so others can learn from that experience.
    regarding warranty, its 3 years or 100K KM whichever comes first.
    Jun 2009
    #710
    Sir av8or5
    It was already closing time sa mits shop( around past 5pm)actually its my wife who brought the strada to the shop. Mits commonwealth assigned service technician that handle under warranty rides, parang mayroon lang kinalikot & bleds some fuel line, baka raw nakapag karga kami ng offspec na diesel ,sinabi ko sa mrs. ko ang suspect ko na SCV ang problema siguro where she convey to the technician kaya ang sabi after fixing the problem na pag umilaw uli yung warning lights ibalik uli sa kanila, hindi na nga nag ilaw but yung momentarily lost of power ang na observe namin.
    RTS
    Oct 2004
    #711
    Hi!
    Got my Rosita Red GLX last August 12. Already switched the headlight bulbs to Philips X-treme Power, added Stebel GP2 airhorn behind the front grill and disconnected the stock horn, changed the wheels to 15x9 Mamba M5 +12offset with Cooper Discoverer ATR 31x10.50 tires, and installed original grey color Carryboy fender flares.
    Will post some pictures soon.
    Aug 2007
    #712
    had the same problem with sir RTS, happens every morning, first 2-3 km na takbo hindi ako makaka-arangkada kac nagkakaroon ng sudden loss ng power, yung tech ng mitsubishi told me na may water daw sa fuel tank ko or sa fuel filter, maybe daw nag pa gas ako ng fuel station na may water na ang tank nila or nagkakaroon lang ng moist sa loob ng tank due to lower sa 1/2 and even 1/4 lang fuel ko palagi...hehehe.nagtitipid eh..... They recommend to drain the fuel tank and palit ng fuel filter. Some said EGR cleaning and sunction cap?hehehe sori d ko nakuha exact term, pero impossible kac bago ba GLS 3.2 A/T ko. Ang ginawa nila is drain the fuel filter, parang may pump ata sa taas nun then they recommend na palagi daw full tank or hindi baba sa half ang fuel ko to avoid moist daw sa loob ng tank. And that's what I did, as of now ok na sya, but napansin ko lang everytime na nasa 1/4 or lower sa 1/4 ang fuel ko bumabalik ang sudden loss ng power every morning at 2 to 3km ng takbo pero after magpagas uli ako ng half or full tank nawawala naman. sa ngayon na palagi full tank bago ako mag park sa bahay ayun wala ang problem.
    But they recommend heavy check up sa 40k ata, kasama na dun EGR cleaning and iba pa pero estimate nila mga 14-15k daw magagastos sa heavy check up.....hehehehe
    Aug 2007
    #713
    Quote Originally Posted by doy View Post
    Hi!
    sir doy: how much inabot mo sa wheels mo?plan ko kasi within the month mag change ng wheels
    Jun 2007
    #714
    Hi!
    now I can visualize how this Strada looks like.... It's gonna be a head turner.
    Feb 2010
    #715
    sure sir? cause i think wala.
    Jul 2010
    #716
    Hi!
    Sir how much carryboy fender flares? are those original painted gray or gray yung color ng plastic material?
    Mar 2004
    #717
    If you have your key with immobilizer duplicated, it will be good for opening the door only. I duplicated my key also and keep it in my pocket, just in case the original key is left inside the vehicle.
    Aug 2007
    #718
    Hi!
    congrats sir!
    Sep 2004
    #719
    Hi!
    congrats sir. we can't wait to see your ride. if you got time, i hope maka join ka sa mindanao chapter of TSCP.
    medyo O.T... ive noticed soap teleserye ng channel 2, they are using Strada in some of the episodes. hahahahah.
    Aug 2010
    #720
    Quote Originally Posted by rss View Post
    Last time I checked, mga 1st week ng Aug., 8,500 po price nila sa Carryboy The Fort. Body color na po yon or your choice of paint color. Same price and paint din sa 14pcs. body cladding. HTH
2010 Mitsubishi Strada [continued]
