Page 391 of 501 FirstFirst ... 291341381387388389390391392393394395401441491 ... LastLast
Results 3,901 to 3,910 of 5002
    Sep 2004
    #3901
    Quote Originally Posted by RF02 View Post
    gusto ko sana yun makapal yun goma sir eh para mabawasan yun fender gap... tumaas yun ride onti and added comfort sa ride.
    kaso ayaw ko naman palitan yun mags as of now
    pero kung kagaya ng sabi mo na imposible talaga sa stock rims...
    baka magipon nalang ako para isang palitan nalang mags and tires :D
    tyvm sir :D
    Almost the same as my question before... Sayang yung 16" mags so para mas malapad at konting taas kesa stock tire na 205/80-R16 pwede pamalit yung 245/70-R16. Ang pagkakaiba nila:
    Width 245-205=40mm
    Thickness (245*0.7)-(205*0.8)=171.5-166.4=5.1mm
    Or additional 10.2mm sa diameter
    I already saw 245s fitted on 16" stock rims on a strada here in Pasig city. Sinulat ko talaga yung size ng makita ko. Astig sya tingnan sa unmodified glx body. Itong goma ipapalit ko once napudpod na stock tires.
    Apr 2008
    #3902
    Quote Originally Posted by D3nb3r View Post
    I was planning to do the same thing in the future pag naka bili na ako nang G500 canopy. I didnt think it was a viable plan before dahil medyo malaki ang gap ng main cabin sa canopy area. Anong rubber seal po yung ginamit for the gap between the canopy and the main cabin?
    Not so sure as to what kind of rubber seal. Basta medyo makapal and seems to resemble the rubber sealing on the doors. However kapag napakalakas na ng ulan, minsan may tumutulo...
    Sent from my GT-I9100 using Tapatalk 2
    Oct 2005
    #3903
    Hello po baka may naka experience po kayong ganito? yung unit ko po is 2012 strada na may 16k mileage ang issue ko po is yung driver side na fog lamp nung sasakyan ay nag momoist covering yung buong glass at 2 to 3 days sya bago mawala even with use of fog lamp light. para saakin at sa mga nakausap ko hindi po ito normal. yung sa passenger side na fog lamp ay hindi naman nag moist kahit kelan. Tumawag narin po ako sa MMPC at yung technical na taong nakausap ko ay sinabing hindi daw normal yung ganito at product defect ito. Nung nag claim naman ako sa EMC sabi nila dineny daw ng MMPC yung warranty claim nila. Meron po bang naka ranas ng ganito? sana po may makatulong. salamat
    Sep 2004
    #3904
    Quote Originally Posted by jun_gats View Post
    ...Nung nag claim naman ako sa EMC sabi nila dineny daw ng MMPC yung warranty claim nila. Meron po bang naka ranas ng ganito? sana po may makatulong. salamat
    Bro I suggest you get your warranty booklet and owner's manual. Basahin mo doon ang coverage ng warranty. Minsan ko lang binasa ang booklet madali pa kaya hindi din ako sigurado kung covered ang mga ilaw. Sakaling covered, then you can formalize your complaint in a letter citing the coverage. Kung hindi covered, you can still write your complaint stating your disappointment for a defective product.
    Good luck! By the way ano yung EMC?
    Oct 2005
    #3905
    Quote Originally Posted by CtrlAltDel View Post
    Maraming salamat bossing pero covered sya. 3 yrs ang warranty nila or 100k m kaso ang pagkakaintindi ng mga tao from MMPC and EMC ang magulo. Would you agree na dapat magkaroon ng tubig sa fog lamp at headlight mo? This is defenitely not normal but they are saying it is normal.
    #3906
    Ang nasa manual, it is normal na magka moisture sa headlights / foglamps.
    Ang hindi normal e mag moist tapos hindi nawawala after a few days. Or kung mawala man, e may water spots sa loob. If you can, try to see kung tama ang pagka mount ng bulbs sa fogs mo. Nasa manual din ang instructions kung pano gawin yun.
    Please read the manual.
    Jul 2013
    #3907
    Width 245-205=40mm
    wow thanks so much sa info na ito matry nga magcanvass atleast meron na hope!!
    hindi po ba mavvoid warranty kung goma lang papalitan sir?
    Mar 2012
    #3908
    Quote Originally Posted by GTi View Post
    ah, ganun ba sir. so hindi parin pala water tight yung seal na ginamit nila. may pics po ba kayo nang seal na ginamit?
    Anong basis nila to say na normal lang ang ganun ka tagal na moisture inside fog lights? more improtantly on what grounds bakit na deny yung claim mo? Check the written report if there is any.
    Apr 2008
    #3909
    Hmm... Medyo mahirap makita yung goma but this pic shows a bit of it. Some of it is visible from the upper corners. I doubt they can really make an utterly watertight seal since it wasn't really designed for that.
    Oct 2005
    #3910
    Ito ang reply nila sir.
    Our Customer Care Team has coordinated your concern with our Service Department and your servicing dealer, Evolander Motor Corporation (EMC). Based on their technical findings, the headlight usually has moisture inside its body. As the headlight is turned on, the temperature of the light bulb with its surrounding parts will increase and the water around those parts will evaporate. Thus, the absolute humidity inside the headlight goes up. If the front surface of the headlight (i.e. front lens) is cooled down by rain shower, car wash, or even cold wind, the temperature of the lens becomes lower than dew point of the air inside the headlamp body. Under this condition, dew concentration will occur on the headlight lens inner surface. Please understand that this is a normal phenomenon called "Condensation" and is not a product defect.
    Humihingi ako ng spec sheet ng fog lamps pero wala daw sila. I cant believe na wala sila nito kasi requirement ito ng product at dito nakalagay yung details ng fog lamps. Tinatanong ko din yung breather kung single or dual ang function nya hindi rin nila alarm. Sa tingin ko its more on the technical knowledge ng taga MMPC at sa EMC. kasi hindi nga nila alam yung spec sheet. Sabi ko din pari ang fog lamps, left and right pero right lang ang nag kaka ganito, sabi ko din sa kanila na hindi dapat naghahala ang water at electricity. I think I had enough sa kasang ito at lilipat nako sa iba. salamat
2010 Mitsubishi Strada [continued 2]
