Results 3,571 to 3,580 of 5002
July 28th, 2013 09:03 PM #3571
- Aug 2009
- 181
July 28th, 2013 09:50 PM #3572+12 sau and -12 sakin equals 24mm or 2.4cm / 1 inch and base sa pics mo sir nakalabas na meaning mas lalabas yung -12mm sakin, ok lang naman ako sa tilamsik ng putik ang kaso tingin ko lang hindi maganda yung masyado nalakabas kung hindi naman naka lift parang mas maganda yung nakalabas basta nakalift sakin lang naman yun. sige sir try ko yung 2 na binanggit mo na shop and pag wala rockwell baka nga sa mojave na din ako bumagsak ang pagipunan nalang ulit yung pagpa lift, sa jeff's nalang sa baguio siguro kasi me discount daw yung tropa kong me trucking na taga baguio sa kanila, ewan ko lang kung binobola lang ako hehe.
- Aug 2009
- 181
July 28th, 2013 09:55 PM #3573nice info sir, bopols kasi ako sa offset thing na yan eh, anyway mukhang walang choice kungdi lumabas nga eh para kasing lampa ang truck namin na naka glx pag stock ang gulong eh no offense meant sa mga naka stock pero truck na truck kasi pag pinalapad pa, lalo na kung naka lift and bumpers pero matagal pa yun ang mahal eh hehe.
July 28th, 2013 10:44 PM #3574
yes sir matikas talaga ang stance nang rig natin pag malaki and malapad ang tires. but it all comes down to personal preference. kung yun talaga ang gusto mo then go with it. you're the one that's going to drive your rig anyway. kaya as for me, i don't care if umabot pa sa roof ang mga putik and dumi as long as i'm satisfied with how my rig looks and performs then ok lang
- Aug 2009
- 181
July 29th, 2013 08:28 AM #3576
July 29th, 2013 10:59 AM #3577
i don't know much about the tires you've mention. i'll just give some overview na lang. stock gls tires are 245/65/17 the monty has a 265/65/17. if you think those tires are heavier than the stock glx? well, later models of strada share the same engine w/ the monty (vgt or non-vgt) except for the monty se, so basically there's not much of a difference if you switch to oem tire size of the monty/gls. pros? wider tires means more rubber on the road and bigger tire looks good
sir lakers24: 265/65/17 is still safe for strada. a lot of guys and even a friend of mine switched to oem monty size tires and rims.
- 217
July 29th, 2013 11:13 AM #3578Wheel Offset Explained - Stop guessing and wondering
Eto mga pre nakuha ko sa FB ng strada club maganda explanation ng offset. makakatulong sa ating mga baguhan hehehe
July 29th, 2013 11:46 AM #3579
Kung oem tire ba ng montero fitted sa strada wala ba siyang stick out kahit walang fender flare?
July 29th, 2013 12:24 PM #3580
i also do not know what he meant by "dim". when my since-new 2005 innova's headlight housings...
Dim Headlights Problem
