Results 1,531 to 1,540 of 5002
May 8th, 2011 05:57 PM #1531
See page 68 of this thread or check this link http://tsikot.yehey.com/forums/showthread.php?t=42667
Sa strada nasa left part ng engine yan if you are facing your car. HTH. You can block the EGR by the old sinturon trick or put a small ball bearing.Fasten your seatbelt! Or else... Driven To Thrill!
- Jan 2011
- 27
May 8th, 2011 07:21 PM #1532
May 9th, 2011 12:08 AM #1533
Sir just reminder po sa mga mag block iba po yung design nag lumang 4D56 sa magong design if you miss block po ang EGR mag check engine po siya well experience na po yan nag ibang strada owners po.
May 9th, 2011 10:04 AM #1534
Yes Sir, I agree with you about the accumulation of carbon during slow or idle mode, In my case always city driving lang ang truck ko (3.2 A/T), alam mo naman ang trapik, when I was still sailing it is always the problem of our engine ( 35K horse power) carbon deposit during idle mode, we are using chemical to remove it (strong smelling) sana meroon pwede i-mix sa engine natin.
Thanks, I will try to look for SCV you mentioned.
Rgds.,
RTS
May 9th, 2011 10:41 AM #1535
Sa Blade sa MOA may nakita ako na ready-made na eh. P2,000 ata? I forgot the price eh.
Yung hoe will be from the valve cover to the OCC and the the return hose will be from OCC to the breather hose of the air filter.
pics c/o Pajero Guru Promdiboy from this link http://tsikot.yehey.com/forums/showt...=72558&page=53
As you can see, blank na rin EGR niya.Fasten your seatbelt! Or else... Driven To Thrill!
May 9th, 2011 12:52 PM #1536
Hi,
Im thinking to install Oil Catch Can in my truck, does it helps in correcting carbon deposit in our EGR, same time prolong the life of SCV, anybody out there tried the OCC in your stradas, what is the feedback.
Thank you- RTS
- Mar 2009
- 154
May 9th, 2011 01:08 PM #1537Good day mga Sir,
I just brought my unit sa Citimotors this day, the SA told me to clean the EGR and intake manifold, cost around 1800 and 500 for the chemicals to clean the carbon deposits.
I ask the SA for quatation on how much to clean the aircon, I was shocked of the price because it was around 18k, He said it includes replacement of expansion valve and dry filter. Denso company is the one who will clean the aircon. Is it worth for that price? or do you have any recommended shops where my aircon can be cleaned?
Meron bang Denso shop sa labas where i can get the original expansion valve and filter dryer? Sobrang mahal magpalinis, para ako bumili ng window type aircon hehehe 1.0 HP na carrier heheheh.
Yun na lang kaya ilagay ko aircon sa strada, total nabubuksan naman yun window sa likod heheh, tamang tama
May 9th, 2011 04:12 PM #1538
Sir RTS it will definitely lessen the carbon deposit in your truck since the oil mist from the exhaust will not be recirculated in the combustion chamber. The EGR works during idle and even then, moist from blow-by is present so it definitely will lessen carbon deposit. Change your fuel filter every 10K kms din and use baldwin, fleetguard or bosch fuel filter since mura na at mas maganda pa filtration ability vs. OEM and replacements. My thread niyan si dvldoc.
Sa mga Pajero guys dami na gumamit ng OCC na yan.
hehe, kung hindi pa naman mahina aircon, wag mo muna palinis. After warranty or 3 years, din puwede na sa labas na lang ng casa IMO par mas mura. That is if you want to save on the warranty of the vehicle just in case.Fasten your seatbelt! Or else... Driven To Thrill!
May 9th, 2011 06:42 PM #1539
May 10th, 2011 08:12 AM #1540
Xiaomi E-Car
