Results 1,371 to 1,380 of 3019
January 18th, 2012 11:54 AM #1371
January 18th, 2012 11:55 AM #1372
January 18th, 2012 12:02 PM #1373
January 18th, 2012 12:50 PM #1374
Tsikot Member Rank 1
- Jul 2009
- 4,090
January 18th, 2012 02:07 PM #1375If your unit is navigation ready, all you need is just an updated map specifically designed for your avt unit. Its roughly around 300mb file and definitely will not cost you 6k just to have it. If your unit is the same with the SE which i believe has a navigation, all you need is that sd card, just copy it. Also dont believe them when they said you need a special sd card for that, i have used old sd cards from my "baol" and just download and follow the procedure from inav.ph, for as long as you have the correct map for your avt, its perfect. I have also tried downloading maps of different avt model, the maps are distorted. The question is, does inav.ph have the specific map your avt needs, if yes , well and good, if not, you are trapped as of now
- Dec 2011
- 34
January 19th, 2012 01:28 AM #1376Guys! Advice naman po. Newbie palang ako about sa mga cars but I have rred asx :D Question ko lang. Anong gas kinakarga nyo and ano advantages/disad? Gamit ko kasi sa ngayon petron extra unleaded. Tapos may napansin din ako sa ASX ko. yung sa Handbreak nya. Mejo maluwag.mejo Na momove sa side. Pwede ba yun pasikipan?
Tnx sa makakatulong
January 19th, 2012 03:11 AM #1377
May discussion na dito about sa gas na gamit nila try to read previous posts. Di lang gas matutunan mo. About sa handbrake medyo maluwag nga at nagagalaw from side to side. It doesn't bother me pero gusto ko din ipa check kung pwede pahigpitan. Sa next check up na lang siguro.
- Nov 2009
- 1,756
January 19th, 2012 06:32 AM #1378RON 93 to 100 are all fine & no big difference in performance. Me, I use premium.
The same with me but its fine & not worse. Dont use it sideways, intead back & fort. (smile)
I advice to let it that way, if you will try or somebody will repair for it, expect some parts to be dismantled. Might repair your worry but it may dis allign or damage some of its adjacent part(s).
- Dec 2011
- 34
January 20th, 2012 04:19 AM #1379Guys! questioon ulit. Pano ba talaga gumagana yung Auto door lock? Meron ba tayo n2? na notice ko lang nag autolock ASX ko dati. umalis lang ako sa garahe ng hindi naka lock then after a few seconds naka lock na yung doors. Pero parang hindi laing ganto? HAHA. Pano ba talaga to nag wowork?
Tapos survey lang. Ano favorite nyong accessory sa ASX nyo? aside sa gulong :D yung hindi din mavovoid yung warrantyYung headlamps nakakatemp palitan T.T
January 20th, 2012 05:18 AM #1380
I am happy for you. We had a very bad experience with VW Philippines. We will avoid getting from...
China cars
