Results 11 to 12 of 12
June 7th, 2011 01:59 PM #11
older 4d56 turbos are rated 84 brake hp (first gen pajero). the newer ones (i think after 1993) gives 100.
and yes i agree (again), that in the long run, 4M40 may prove to be cheaper to maintain.
andami ko na kaya nagastos sa 56 ko.halos timing belt ang kumain sa budget.
pero as per my review on the service manual the 4M40 does not have self adjusting valves. yes the rocker arm-shaft assy is absent but the adjustment of valve clearance is via a shim located in between the camshaft lobe and the end of the valve. a simple math work is involved here since you have to measure the gap while its installed as well as the indicated size on the installed shim and take into account the wear on the cam lobes and available shim sizes at auto stores.Last edited by miked; June 7th, 2011 at 02:06 PM. Reason: added info
June 14th, 2011 07:29 PM #12
Masaya na ako sa 10km/L sa SCTEX, semi hataw mode na yun. Hehehe Sent from my iPhone using...
Traffic!
