Page 462 of 582 FirstFirst ... 362412452458459460461462463464465466472512562 ... LastLast
Results 9,221 to 9,240 of 11634
    oo ako
    spilling level by end of year
    Diba may kapustahan ka kags? [emoji28]
    This time i cannot really brag kasi
    - its covic pandemic not real use of water pero pwede sabihin madami naghahandwash and lalo na sa hospitals mataas consumpiton nila so im not reallly sure pa
    - If this is a true la nina eh maliit itong angat dam. Magpapakawala lagi yan sa rice fields.
    - and kahit mapuno si angat eh kulang talaga sa population ng pinas. Every year lagi ako nakanbantay umaasa na umulan.
    - by summertime and pag pasok ng june eh delikadengdeng na level nyan. So shortlived ang kasiyahan ko. (buti sana kung usapang true qc na stable all year hindi nagbabago kalsada maluluwag. )
    So ito yung sinasbi ko na we need water reserviori inside metro manila and stop na residential condominum.
    Kasi its not yearly na may ganito la nina.
    Eh paano kung mag elnino sa sunod. (kahit elnino kayang punuin angat dam. Madami lagn talaga tao sa pinas
    Dapat si fabella hospitals hindi na libre pagbubuntis. Mga mokong ito buntisan-buntisan sa probinsya. Dumadayo pa talaga ng metro manila para makalibre. Eh sarado ngayon kasi nagkacovid medical staff. Wag na nila i-open yan 6months.
    #9223
    no rest for the weary as another tropical depression makes a beeline for the provinces of bicol and samar.
    Approaching TD 'Rolly' seen to intensify into a typhoon, may hit Bicol Region, Eastern Visayas anew
    4.70
    198.80
    0.85
    199.65
    Matthew Santiago Cuyugan
    2h
    JMA now forecasted a direct hit of the Tropical Depression pre-#RollyPH in Metro Manila as a typhoon on Sunday afternoon.
    This could be the strongest typhoon to hit Manila since #GlendaPH (#Rammasun) in July 2014.
    Note: Subject to change.
    134
    37 comments
    187 shares
    Ronan Aglipa
    2h ·
    Magbabago pa yan
    Matthew Santiago Cuyugan to Ronan Aglipa That's why I put "subject to change." ��
    3
    Like
    · 2 h
    kagalingan of tsikot forum : Basta mapuno angat dam hanggang march nasa spilling level happy na ako.
    NCR ba tatamaan?
    #9228
    NCR ba tatamaan?
    based on the pictures,
    it would appear so.
    rant.
    it might appear obvious to the weather folks,
    but it may not always be so, to us ordinary mice.
    we sometimes need explanations.
    for example,
    the above images.
    the probability circle is huge!
    #9229
    that would probably depend on where one's house is located.
    what if it is downriver from da dam?
    may tumutulak kasi sa bagyo pababa
    dapat pataas yan papunta northern luzon
    Kailangan na ba ilabas yun gen set?
    NCR ba tatamaan?
    More likely sa Pampanga area tatamaan...
    pag humina ung high pressure area na tumutulak sa bagyo pababa... aakyat ung bagyo
    So hinde na talaga dadaan Manila?
    sa radyo kanina sabi Quezon province daw landfall
    dito sa thread sabi direct hit ang NCR
    di ko alam tuloy....
    pero sure maulan yan kahit di direct hit ang NCR
    Parang hinde na yata direct hit NCR and yun super typhoon na kasunod mukhang sa extreme north and daan. It will be the biggest typhoon daw for this year worlwide.
    Bukas na siguro ako bibili ng gasolina for genset Sunday pa naman yata yun effect dito sa manila.
    The longer it stays over the ocean lalong lumalakas... unlike the previous storms mahina pa at dumaan na ng PH.
    #9238
    Yes bro.,- time to check [again] if the genset would be there for us...
    Bukas paandarin ko. Napapandar mo pa rin regular? Can't remember when I tested mine. Probably early this year.
    #9240
    Yes bro.,- although not loaded in the past months.... Doing this exercise every month for 15-30minutes...
    Need to 'burn' the gasoline.....
Weather TALK [forecasts, etc]
